  4. Deleting Entities by Name
3 Posts 2 Posters 1.5k Views 2 Watching
  • E Offline
    E Offline
    ebarkoch
    Does anyone know how to delete entities within a model using the Python API. In the example below, I'm trying to delete all entities named "electrode" but the delete doesn't remove them from the UI. I confirmed that the if statement is indeed working.
    Thanks.
    entities = model.AllEntities()
    	for i in range(len(entities)):
    		name = entities[i].Name
    		if "electrode" in name.casefold():
    			entities[i].Delete
    AntoninoMCA 1 Reply Last reply
    • E ebarkoch
      Thanks.
      			entities[i].Delete
      AntoninoMCA Offline
      AntoninoMCA Offline
      AntoninoMC
      @ebarkoch
      The issue in your code is in the last line of the code. You should write entities[i].Delete(). Also please check the indented blocks.
      The code should be:
      All the best,
      Antonino
      E 1 Reply Last reply
      2
      • AntoninoMCA AntoninoMC
        @ebarkoch
        The code should be:
        All the best,
        Antonino
        E Offline
        E Offline
        ebarkoch
        @AntoninoMC thanks, that worked perfect!
