  4. read output files
read output files
3 Posts 2 Posters 1.6k Views 2 Watching
    michaelsch
    hi
    after simulation completed saved files :
    input.h5
    output.h5
    i want to use python to read the output data voltages x,y,z as generated after simulation completed
      I would recommend to perform the postprocessing in the GUI first, then right-click in the Explorer window of the Analysis tab and select "To-Python" in the context menu. This will generate a script (visible in the Scripter window) that reproduces your postprocessing pipeline. You can then modify the script to your liking.
        michaelsch
        wrote on last edited by michaelsch
        solved with h5py read :
        import h5py
        with h5py.File(fname,'r') as hdf:
        FieldGroups=hdf['FieldGroups']
        keygroup = list(FieldGroups.keys())
        valField = FieldGroups[keygroup[0]]
        AllFields = valField['AllFields']
        EMPotential = AllFields['EM Potential(x,y,z,f0)']
        EMPotentialObject = EMPotential['_Object']
        AdditionalFieldDataCollection =
        EMPotentialObject['AdditionalFieldDataCollection']
        Snapshots = EMPotentialObject['Snapshots']
        Potential = Snapshots['0']['comp0']
        #(n, m, k, 2)  numpy array
        PotentialData = Potential[()]
        this can be plotted
        import pyvista as pv
