  4. PEC extension error in edge source
  • V Offline
    V Offline
    VigneshYork
    I am getting the following error and not sure what is going wrong?
    Error : Edge list of 'Source 6' is empty.
    Error : PEC extension error in edge source Source 6 (Group 7)
    Error : Initialization of the discretization information failed.
    Error : Initialization of discretization failed.
    ofliO 1 Reply Last reply
    • V VigneshYork
      Hi @VigneshYork
      Please carefully check that the voxels of the edge sources are correctly generated. You can use the "Connectivity" mode under in Voxel Viewer to check that the edge sources are correctly connected. If that is not the case, you need to work on the grid to fix the issue.
