  4. Setting camera position and taking screenshot of 3D view with Python API
screenshots3dviewpythoncamera
1 Posts 1 Posters 1.2k Views 1 Watching
    The following function is an example of how to change the camera position and take a screenshot of the 3D view.
    import XRendererUI
    import XCore
    from s4l_v1.model import Vec3
    import numpy as np
    import os
    import pywintypes
    import win32gui
    import time
    import random, string
    def randomword(length):
       return ''.join(random.choice(string.lowercase) for i in range(length))
    def camera(viewname, distance, target, theta):
    	cam = XRendererUI.SaveCamera('')  # load or create a new camera setting
    	cam.OrbitCenter.Value = Vec3(0,0,0)
    	cam.Distance.Value = distance
    	target.Normalize()
    	cam.Orientation.Value = [np.cos(theta/2.)] + list(np.sin(theta/2)*target)  #quaternions
    	#print 'Cam: ', cam.Orientation.Value
    	return cam
    def set_camera(keyword, distance):
    	if keyword == 'current':
    		cam = XRendererUI.SaveCamera(randomword(20))  # create a new camera setting from current view settings
    	elif keyword =='XY':
    		cam = camera('XY', distance, Vec3(1,0,0), -np.pi/2.0)
    	elif keyword =='XZ':
    		cam = camera('XZ', distance, Vec3(0,1,0), np.pi/2.0)
    	elif keyword =='YZ':
    		cam = camera('YZ', distance, Vec3(0,0,1), np.pi/2.0)
    	elif keyword =='ZXY':
    		cam = camera('ZXY', distance, Vec3(1,1,1), np.pi)
    	else:
    		raise RuntimeError('Invalid option (%s) for camera setting' % keyword)
    	return cam
    def makeScreenshots(target_dir=None, distance=200.0, transparent_bg=True, delay=0.001,
    					width=1024, height=1024, prefix='', suffix='',views='default'):
    	if target_dir is None:
    		target_dir = XCore.GetApp().Document.FileFolder
    	assert os.path.exists(target_dir)
    	if views=='default':
    		viewnames = ['XY', 'XZ', 'YZ', 'ZXY']
    	else:
    		viewnames = views
    	assert all([view in ['current', 'XY', 'XZ', 'YZ', 'ZXY'] for view in viewnames]), 'View not implemented'
    	screenshot_paths = []
    	for viewname in viewnames:
    		cam = set_camera(viewname, distance)
    		XRendererUI.RestoreCamera(cam)
    		time.sleep(delay)                 # wait for 3D rendering to complete
    		win32gui.PumpWaitingMessages()  # update view
    		filename = XCore.GetApp().Document.FileName
    		if not prefix:
    			prefix = os.path.splitext(filename)[0]
    		screenshot_name = prefix + '_' + viewname
    		# Workaround to remove counter
    		# delete file if it already exists
    		actual_screenshot_name = os.path.join(target_dir, screenshot_name + '-001.png')
    		desired_screenshot_name = os.path.join(target_dir, screenshot_name + '.png')
    		if os.path.isfile(desired_screenshot_name):
    			os.remove(desired_screenshot_name)
    		XRendererUI.SaveScreenCapture(width=width, height=height, output_folder=target_dir, output_prefix=screenshot_name,
    									  transparent_background=transparent_bg)
    		#actual_screenshot_name = os.path.join(target_dir, os.path.splitext(filename)[0] + '-001.png')
    		os.rename(actual_screenshot_name, desired_screenshot_name)
    		screenshot_paths.append(desired_screenshot_name)
    	return screenshot_paths
    # Example usage:
    # Take 4 screenshots at a distance of 200 units from 4 different view angles
    # and place the pictures (PNG files) in the same folder as the project file.
    if __name__=="__main__":
    	makeScreenshots(distance=200.0, transparent_bg=True)
