  4. Waveport guide error
8 Posts 2 Posters 5.5k Views 2 Watching
  • V Offline
    V Offline
    VigneshYork
    I am trying to simulate a waveguide source for an antenna model I import. But I keep getting the following errors:
    Error : Failed to update waveguide boundaries for small face 1 : Could not deduce the geometry of model small face 1
    Even, if I reconstruct the waveguide, it does not work.
    How do I resolve this?
    • ofliO Offline
      Which waveguide source are you using? How big is the waveguide aperture? If you can share your project, I can have a look. Alternatively, please send the screenshot of the source section of the model.
      • V Offline
        V Offline
        VigneshYork
        wrote on last edited by VigneshYork
        I am trying to use a coaxial waveguide source. I have shared the project in the following link:
        https://drive.google.com/file/d/1E3Vi21v6aqLaKPqtDiA3_6fN79DxMVT8/view?usp=share_link
        I would like to power the patch in the antenna
        Thank you
        • V Offline
          V Offline
          VigneshYork
          I have tried adding a third cylinder around the ports and extracting the edges. But seem to get the similar error. Would I need to unite the coaxial feed and the patch?
          • V Offline
            V Offline
            VigneshYork
            Hi, I think I have managed to solve the problem. Thanks
            One question, how to reverse the signal from a waveguide port?
            For example, I have 2 waveguide ports and I want to power one of them with a 180 degree phase shift to the other. Is that possible?
            • V Offline
              V Offline
              VigneshYork
              any idea how to proceed on this topic?
              Thanks,
              • ofliO Offline
                wrote on last edited by ofli
                #7
                Hi, I am not sure if I understand your application well. After you simulate 2-ports case as a multiport simulation, you can then use Simulation Combiner in Analysis to set Available Power and Phase of each ports. Please refer to Section 2.13.7.5 Extraction of Results from EM-FDTD Multiport Simulations in the manual.
                • V Offline
                  V Offline
                  VigneshYork
                  I would like to power the two waveports with an input which is 180 degree phase apart between each other. The antennas are constructed in a differential manner to increase penetration. I am not sure how to provide the power input to the waveport guide
