  4. ERROR: An aXware function call failed and reports:
  • W Offline
    W Offline
    wouterverhelst
    I came across the following error while trying to simulate using aXware. I have never seen it before and my simulation fails because of it. Does anybody know what to do?
    ERROR: An aXware function call failed and reports: Invalid parameter value.: CustomHardSpatialExcitation time shifts must be within range [-8,300,000, 8,300,000].
    ofliO 1 Reply Last reply
    • W wouterverhelst
      Hi @wouterverhelst
      This error can appear with simulations having a non-optimal grid with at least one very small cell leading to a very small step size. Could you please inspect the grid in your simulation and see if it can be improved? Please use "Connectivity" option in voxel view to make sure that the source is connected. If possible, please share more info, for example, parts of the log file where you can see min grid step, time step and initialization of source(s):
      [INFO]: Number of cells: …
      [INFO]: Number of cells including PML: …
      [INFO]: X: Range [.. ... .. ] with minimal .. and maximal step ..  [m]
      [INFO]: Y: Range [.. ... .. ] with minimal .. and maximal step ..  [m]
      [INFO]: Simulation Time Step:	…  sec
      [INFO]: Sources:
      [INFO]: Initializing edge source Lines 1  (Sources) …
