  4. How to compute the length of a spline using the Python API
splinepythonapi
2 Posts 2 Posters 2.4k Views 2 Watching
    import XCoreModeling
    def get_spline_length(spline):
        wire = XCoreModeling.GetWires(spline)[0]
        target_curve = wire.GetGeometry(transform_to_model_space=True)
        target_path = target_curve.GetLaw()
        target_path_start = target_curve.ParameterRange.Start
        target_path_end = target_curve.ParameterRange.End
        return target_path_end - target_path_start
    # usage example
    s = model.AllEntities()['Spline 1']
    s_length = get_spline_length(s)
    print 'Length of spline {} is: {}'.format(s.Name, s_length)
    • PeterStijnmanP Offline
      PeterStijnman
      wrote on last edited by PeterStijnman
      Works perfectly, thanks!
      Edit,
      I think you could also get away with:
              return wire.GetLength()
