  4. Exporting data to excel (csv) or matlab (mat)
6 Posts 3 Posters 3.6k Views 3 Watching
    rediponi
    I have generated a set of simulations and i would be interested to export some information like:
    1 - SAR slice : How to determine the slice number which is closer to a coordinate: lets say at 0cm but due to gridding it corresponds to 0.013 cm.
    2- In the extracted SAR slice I am interested in the SAR values in a line along for example Y-axis. Again i know the absolute value of the line but i dont know exactly to which coordinate would correspond due to gridding.
    I generated a python script of a manually extracted line, then i run the generated script, but it gives errors.
    Could you show an example script of generating and exporting the SAR slice and a line in that slice?
    SylvainS 1 Reply Last reply
    • R rediponi
      1. You need teh function FindCell (see example below)
      2. You also need FindCell, together with raw access to the underlying numpy data array and a way to "reshape" it properly (see same example below)
      	simulation = document.AllSimulations["SCC34 Benchmark Simulation"]
      	em_sensor_extractor.SurfaceCurrent.SurfaceResolution = 0.001, units.Meters
      	# Get data object
      	em_sensor_extractor.Outputs["SAR(x,y,z,f0)"].Update()  # output needs to be updated before extracting data
      	sar = em_sensor_extractor.Outputs["SAR(x,y,z,f0)"].Data
      	# a location in space:
      	x = 0
      	y = -0.00910
      	z = -0.00025
      	# get grid cell indices closest to that location:
      	id_x, id_y, id_z = sar.Grid.FindCell(x,y,z)
      	# Create Slice Viewer at that location
      	inputs = [em_sensor_extractor.Outputs["SAR(x,y,z,f0)"]]
      	slice_field_viewer = analysis.viewers.SliceFieldViewer(inputs=inputs)
      	slice_field_viewer.Data.Mode = slice_field_viewer.Data.Mode.enum.QuantityRealModulus
      	slice_field_viewer.Slice.Index = id_z
      	slice_field_viewer.UpdateAttributes()
      	document.AllAlgorithms.Add(slice_field_viewer)
      	# Get raw data array (in the form of a numpy array)
      	sar_array = em_sensor_extractor.Outputs["SAR(x,y,z,f0)"].Data.Field(snapshot_index=0)
      	nx, ny, nz = numpy.array(sar.Grid.Dimensions) - numpy.array((1,1,1))  # grid is defined on nodes, SAR data is in cell centers
      	sar_array = numpy.reshape(sar_array, (nx, ny, nz), order='F')
      	# now data can be accessed easily:
      	print sar_array[:, id_y, id_z]
      R 1 Reply Last reply
      • SylvainS Sylvain
        	# Get data object
        	x = 0
        	y = -0.00910
        	z = -0.00025
        rediponi
          rediponi
          Thank you Sylvain.
          Could you possibly add one example of code writing array (for the line) or matrix ( for the slice ) using the Matlab export ?
            Currently the Matlab exporter only allows exporting a whole quantity (i.e. the whole 3D array if it is a 3D quantity, like the SAR(x,y,z,f0)).
            Once exported, though, it is relatively straightforward to slice through the array in Matlab. See for example this post: https://forum.zurichmedtech.com/topic/47/exporting-data-to-matlab-how-to-access-the-data-as-a-volume-matrix
            • AntoninoMCA Offline
              AntoninoMCA Offline
              AntoninoMC
              Dear Redi, you can export arbitrary data to Matlab (e.g. field array and grid coordinates) using the Scipy.io library. A generic use of it is the following:
              import scipy.io as sio
              dict={'field':fieldarray,'xgrid':xgrid,'ygrid':ygrid,'zgrid':zgrid}
              sio.savemat(filename,dict)
              where xgrid,ygrid,zgrid are the vectors containing the cartesian coordinates of the grid.
