  4. How to create solid circle ie. with surface ?
Scheduled Pinned Locked Moved Solved Python API
4 Posts 2 Posters 1.9k Views 2 Watching
    dbsim4
    wrote on last edited by dbsim4
    I'm trying to make a circle as a solid 2D surface (ie. filled in) with the Python API using s4l.model.CreateCircle(...)
    But it's showing up as an empty ring (ie. a 1D line circle, no fill).
    How can I fill it in so that it creates a solid circular surface (flat 2D, not like a 3D cylinder).
    Thank you!
    • Doug
    brynB 1 Reply Last reply
      dbsim4
      Update: The intersection method didn't work:
      Unable to assign '....' as a Waveguide Source in simulation 'EM'
      • I'm not sure why it's trying to make it a waveguide (I intend to use Edge sources); but I'm assuming it's failing because of the curved geometry of the intersection with the arc of the circle... so... ideas? It would be perfect to connect the gaps in the circle with lines. I just need to be able to find the endpoints of each arc, to connect them.
      • D dbsim4
        Thank you!
        • Doug
        @dbsim4
        This is the same behavior as in the GUI. To create a circular surface you can first create a circle loop, and then cover the loop. In python:
        # create a circle loop
        circle = XCoreModeling.CreateCircle(Vec3(0, 0, 0), Vec3(0, 0, 1), 5.0)
        # cover the loop
        XCoreModeling.CoverWireBody(circle)
        Note the s4l_v1 api is a wrapper around the low-level API implemented in modules like XCoreModeling. We don't automatically add all functions to s4l_v1. While CreateCircle is wrapped/included in s4l_v1, the function CoverWireBody is not (yet) wrapped.
        • D dbsim4
          @dbsim4 regarding your "Update", I am not sure I understand the context. Are you trying to assign the circle loop as an edge source?
          • SylvainS Sylvain has marked this topic as solved on
