  4. Padding field with constant value
1 Posts 1 Posters 710 Views 1 Watching
    Recently a user asked how they could extract a closed surface from a field, e.g. at the iso-value contour of a field distribution.
    I answered that you can extract the iso-contour surface using the IsoSurfaceViewer.
    The problem was then that the iso-surface can be open, if the iso-value passes through the boundary. So I suggested to pad the field with a constant value (e.g. very small value) first, forcing the contour surface to be closed at the border.
    But how can you pad a field using the Sim4Life api? Since this may be useful/interesting for other users I would like to share a snippet showing how this can be achieved:
    import s4l_v1 as s4l
    from s4l_v1 import Unit
    import numpy as np
    def create_rectilinear_field(nx: int, ny: int, nz: int, num_components: int = 1, cell_data: bool = True, value: float = 1.0):
        def make_quantity(name: str, unit: str):
            quantity = s4l.analysis.core.Quantity()
            quantity.Name = name
            quantity.Unit = Unit(unit)
            return quantity
        grid = s4l.analysis.core.RectilinearGrid()
        grid.XAxis = np.array(np.linspace(-0.15, 0.15, nx))
        grid.YAxis = np.array(np.linspace(-0.25, 0.25, ny))
        grid.ZAxis = np.array(np.linspace(-0.3, 0.3, nz))
        grid.Unit = Unit("m")
        num_tuples = (nx - 1) * (ny - 1) * (nz - 1) if cell_data else nx * ny * nz
        location = s4l.analysis.core.eValueLocation.kCellCenter if cell_data else s4l.analysis.core.eValueLocation.kNode
        field_data = s4l.analysis.core.FloatFieldData()
        field_data.Grid = grid
        field_data.ValueLocation = location
        field_data.Allocate(1, num_tuples, num_components)
        field_data.SetField(0, np.random.rand(num_tuples, num_components))
        field_data.Quantity = make_quantity("EM E(x,y,z,f0)", "V/m")
        field_data.SnapshotQuantity = make_quantity("Frequency", "Hz")
        field_data.Snapshots = [1000]
        return field_data
    def pad_rectilinear_field(field_data: s4l.analysis.core.FieldData, pad_width: int = 1, value: float = 0.0, dx: float = 1e-3):
        grid = field_data.Grid
        assert isinstance(grid, s4l.analysis.core.RectilinearGrid)
        grid_padded = grid.Clone()
        grid_padded.XAxis = np.pad(grid.XAxis, pad_width=pad_width, mode="linear_ramp", end_values=(grid.XAxis[0]-dx, grid.XAxis[-1]+dx))
        grid_padded.YAxis = np.pad(grid.YAxis, pad_width=pad_width, mode="linear_ramp", end_values=(grid.YAxis[0]-dx, grid.YAxis[-1]+dx))
        grid_padded.ZAxis = np.pad(grid.ZAxis, pad_width=pad_width, mode="linear_ramp", end_values=(grid.ZAxis[0]-dx, grid.ZAxis[-1]+dx))
        data = field_data.Field(0)
        num_components = data.shape[1]
        nx, ny, nz = grid.XAxis.size, grid.YAxis.size, grid.ZAxis.size
        if field_data.ValueLocation == s4l.analysis.core.eValueLocation.kCellCenter:
            nx, ny, nz = nx - 1, ny - 1, nz - 1
        data = np.reshape(data, (nz, ny, nx, -1))
        data_padded = np.pad(data, pad_width=[(pad_width,), (pad_width,), (pad_width,), (0,)], mode="constant", constant_values=value)
        nx_padded, ny_padded, nz_padded = nz+2*pad_width, ny+2*pad_width, nx+2*pad_width
        data_padded = data_padded.reshape((-1, num_components))
        field_padded = field_data.Clone()
        field_padded.Grid = grid_padded
        field_padded.Allocate(1, nx_padded * ny_padded * nz_padded, num_components)
        field_padded.SetField(0, data_padded)
        return field_padded
    if __name__ == "__main__":
        field = create_rectilinear_field(20, 23, 29, 1, True)
        field_padded = pad_rectilinear_field(field, 1, 0.0, dx=0.2)
        source = s4l.analysis.core.TrivialProducer()
        source.AddDataObject(field)
        source.AddDataObject(field_padded)
        document.AllAlgorithms.Add(source)
    This is what it would like in a slice field viewer:
    before padding: f79c7d24-1c0f-4a3c-83dc-005020c23072-image.png
    after padding: 89646de3-f1e9-43f8-9d86-5213b906671f-image.png
