  4. Importing polylines from text file
Scheduled Pinned Locked Moved Unsolved CAD Modeling
2 Posts 2 Posters 1.4k Views 2 Watching
    In Sim4Life GUI-->Import, there is a .txt file format called "outline file files".
    Can this one be used to import a polyline?
    I have polylines defined like a list of points:
    x1,y1,z1
    x2,y2,y2
    xn,yn,zn
    I know this can be done using the Python API, but I was trying to find a way to do it via the GUI.
      You would have to define the polylines in a supported file format, e.g. VTK.
      To create such a file from Python, you could do something like this:
      import vtk
      # define points x1,y1,z1, etc.
      # add the actual points
      points = vtk.vtkPoints()
      points.InsertNextPoint(x1,y1,z1)
      points.InsertNextPoint(x2,y2,z2)
      points.InsertNextPoint(x3,y3,z3)
      # define the lines
      lines = vtk.vtkCellArray()
      lines.InsertNextCell(3) # next line is composed of 3 vertices
      lines.InsertCellPoint(0) # vertex 1
      lines.InsertCellPoint(1) # vertex 2
      lines.InsertCellPoint(2) # vertex 3
      # assemble as surface mesh
      mesh = vtk.vtkPolyData()
      mesh.SetPoints(points)
      mesh.SetLines(lines)
      # write to file, supported by Sim4Life, Paraview, etc.
      writer = vtk.vtkDataSetWriter()
      writer.SetInputData(mesh)
      writer.SetFileName(r"E:\temp\Foo.vtk")
      writer.Write()
