  4. Grid Setting
Grid Setting
3 Posts 3 Posters 1.7k Views 3 Watching
  • O Offline
    O Offline
    Oshrit Zeevi
    Is it possible to create a grid with a constant factor for the differences between grid steps?
    In this example, I tried to have a grid with grid steps that are 0.5, 1, 1.5, and 2 mm, while several entities must have the maximum resolution (arrays_grid, 0.5mm).
    But for the final grid, I get a few steps of 0.8, 1.1, 1.7... mm.
      brown
      One thing you could try and changing the priority settings on different grid folders. However, I'm not exactly sure what you want your grid to look like. Do you want the grid to be graded with successive voxel sizes of 0.5, 1, 1.5, and 2mm? Could you perhaps provide a simple sketch of what you are envisioning?
        I think you can change how the steps change between gridlines with the grading option. If you have some entities that should not influence the grid set priority to zero (for those entities). Then choose the largest grid step you want for the global settings and and the smallest (0.5mm) for the arrays_grid. You should manage to control how the grid changes away from the arrays_grid.
