  4. Cannot run tutorial
Cannot run tutorial
Scheduled Pinned Locked Moved Solved Simulations & Solvers
simulation
3 Posts 2 Posters 1.7k Views 2 Watching
  • J Offline
    J Offline
    jseo977
    Hi
    I have been following the tutorials for EM LF FDTD and NEURON simulations, and they have been working fine.
    However, yesterday I found that the 'Run' button when I press Solver in the Explorer in the simulations tab no longer works. I thought maybe this is because of something I did so I imported a ready-complete tutorial into the workspace to make sure but that too could not run.
    What could be the reason?
    TIA!
      brown
      If the run button is greyed out, it could be because: 1. Your simulation already has results. 2. Your Sim4Life instance lost connection with the solver. If the connection was lost, press the button in the bottom right of the window to open the Task Manager, switch the Networking tab, then click Localhost > Connect.
      • J Offline
        J Offline
        jseo977
        Thank you very much. This fixed the issue. This was related to Ares also.
        • J jseo977 has marked this topic as solved on
