[Error] Input field array is empty
Apologies if this is a silly question, but I cannot seem to figure out why the output of my simulation is not able to show results.
It may be that no results were saved? Does anybody have an idea why this could be the case?When I go on the slice viewer, it doesn't show anything either.
However, there still does appear to be an output H5 file, which I can see is a few GB.
I now see that during the simulation there is a warning:
Warning : The system has no used degrees of freedom (dofs). Therefore, nothing is assembled. This may be related to the simulation not containing any lossy dielectrics, e.g., a requirement for the magneto-quasi-static and stationary current model. Check your model and solid region settings.Though I am still not sure what exactly I should change to fix this issue
