  4. Clear or Reset Geometry Workspace in Python?
pythongeometry
4 Posts 4 Posters 2.2k Views 4 Watching
    dbsim4
    Is there a way to clear or reset the geometry in a Python script? ie. delete all objects & start over?
    If you run the same script multiple times (ie. while developing/debugging) you wind up with multiple geometry objects.
    Currently I'm deleting them by hand to start over.
    What's the recommended workflow for this?
    Thank you!
    • N Offline
      N Offline
      NaraSakamoto
      wrote on last edited by NaraSakamoto
      Happy to stand corrected as I have a very crude way to reset geometries.
      I search for the geometry entities by names and move them together into an entity group which gets deleted as a whole. This was to avoid the ACIS access error when trying to delete entities one by one by iterating over a list of entities. Please let me know if there are better ways to do this!
      def Delete_entities(keyword):
      alist = [ent for ent in model.AllEntities() if keyword in ent.Name]
      if len(alist) > 0:
      EG = model.EntityGroup()
      EG.Add(alist)
      EG.Delete()
      else:
      print(f"Couldn't find entities matching the keyword {keyword} to delete.")
        brown
        You could also delete all of the model entities by filtering by type. Visible geometry objects have type 'body', so you could do:
        entities_to_delete = [e for e in model.AllEntities() if e.Type == 'body']
        for e in entities_to_delete:
        	e.Delete()
          I typically do the following (which also clears the history and frees memory):
          import XCoreModeling as xcm
          xcm.GetActiveModel().Clear()
