  4. Cannot place line as a voltage sensor
4 Posts 2 Posters 1.7k Views 2 Watching
    Byron van Vugt
    Hi
    I've moved to a new computer with a new install of Sim4Life. On prior models this was not an issue, but I now seem unable to drag and drop (Or find an alternative method) for placing a modelled line as a voltage sensor within the model.
    No error shows up, just nothing happens.
    Cheers,
    Byron
      brown
      What version is this happening in? Does Sim4Life show a little circle slash icon when you try to add it?
        Byron van Vugt
        Hi Brown, Its Version 8.0.0. The drag and drop appears as if it is going to work (no circle slash indicating I cannot place the line within the sensor) but the line is not associated with the sensor following the drag-drop process.
        Has the process for associating a line to a voltage sensor changed without any change in the user manual, or is this a bug? If a bug I will look to reinstall Sim4Life as an attempt to remedy it.
          brown
          It looks like this is a bug. Until it is fixed, you can still add line sensors to LF simulations using the API.
          Here is a quick example that adds an entity named 'Lines 1' as a voltage sensor:
          # -*- coding: utf-8 -*-
          import numpy
          import s4l_v1.materials.database as database
          import s4l_v1.simulation.emlf as emlf
          import s4l_v1.units as units
          from s4l_v1 import Unit
          ReleaseVersion.set_active(ReleaseVersion.version8_0)
          # Creating the simulation
          simulation = emlf.ElectroQsOhmicSimulation()
          # Mapping the components and entities
          component__plane_x = simulation.AllComponents["Plane X+"]
          component__plane_x_1 = simulation.AllComponents["Plane X-"]
          component__background = simulation.AllComponents["Background"]
          component__plane_y = simulation.AllComponents["Plane Y+"]
          component__plane_y_1 = simulation.AllComponents["Plane Y-"]
          component__plane_z = simulation.AllComponents["Plane Z+"]
          component__plane_z_1 = simulation.AllComponents["Plane Z-"]
          component__overall_field = simulation.AllComponents["Overall Field"]
          entity__line = model.AllEntities()["Lines 1"]
          # Adding a new VoltageSensorSettings
          voltage_sensor_settings = emlf.VoltageSensorSettings()
          components = [entity__line]
          simulation.Add(voltage_sensor_settings, components)
          # Editing AutomaticGridSettings "Automatic
          automatic_grid_settings = [x for x in simulation.AllSettings if isinstance(x, emlf.AutomaticGridSettings) and x.Name == "Automatic"][0]
          simulation.Add(automatic_grid_settings, components)
          # Editing AutomaticVoxelerSettings "Automatic Voxeler Settings
          automatic_voxeler_settings = [x for x in simulation.AllSettings if isinstance(x, emlf.AutomaticVoxelerSettings) and x.Name == "Automatic Voxeler Settings"][0]
          simulation.Add(automatic_voxeler_settings, components)
          # Update the materials with the new frequency parameters
          simulation.UpdateAllMaterials()
          # Update the grid with the new parameters
          simulation.UpdateGrid()
          # Add the simulation to the UI
          document.AllSimulations.Add( simulation )
