  4. Iso Surfaces - Creating volumes with a threshold
1 Posts 1 Posters 678 Views 1 Watching
    andrea_h
    Hello everyone,
    I am working on an electrical field simulation with electrodes inside an irregular brain structure, and I’m trying to extract a volume containing only voxels with values above 200 V/m. I attempted using IsoSurface for this purpose, but I’m not getting the desired volume output, possibly due to the brain structure's irregularity and the complex E-field distribution.
    Here’s the code I’m using:
    iso_surface_viewer = analysis.viewers.IsoSurfaceViewer(inputs=inputs)
    iso_surface_viewer.DecibelScale = 0
    iso_surface_viewer.IsoValues = (200,)
    iso_surface_viewer.Data.Mode = iso_surface_viewer.Data.Mode.enum.QuantityAbsolute
    iso_surface_viewer.Data.Component = iso_surface_viewer.Data.Component.enum.ComponentsAll
    iso_surface_viewer.UpdateAttributes()
    iso_surface_viewer.Update(0)
    iso = iso_surface_viewer.raw
    iso.CreateTriangleMeshFromIsoSurface()
    With this setup, I don’t capture all the regions with values below 200 V/m, and I'm not sure if I'm missing a setting or approach. Has anyone faced a similar issue or can suggest adjustments to ensure a more accurate extraction of the desired volume?
    Thank you!
