  4. IsoSurface mesh
IsoSurface mesh
    andrea_h
    Hello everyone,
    I'm trying to create a mesh from an iso-surface without relying on its name to access it. When I use the following code:
    mesh = iso_surface_viewer.raw.CreateTriangleMeshFromIsoSurface()
    The mesh variable returns None, although the mesh itself is successfully created.
    Currently, I'm accessing the created mesh by doing something like this:
    ents = model.AllEntities()
    ISO_shell = ents['E(x,y,z,f0) - Iso-Surface Viewer (200.000000 V/m) 1']
    Is there a way to directly reference or store the created mesh in a variable, without having to query all entities by name afterward? Any tips or best practices would be greatly appreciated!
    Thanks in advance for your help!
      this looks like a bug that we will fix for the next update fix release.
      I guess as a workaround you could list all the entities before, and after calling CreateTriangleMeshFromIsoSurface and find the difference, i.e. the one created by the function
        andrea_h
        Hello! Thank you for your quick answer 🙂 I'll do that in the meantime
