  4. How to create voxels using a script?
2 Posts 2 Posters 2.4k Views 2 Watching
    lucky_lin
    Hi, I checked the Python code for the simulation using the To Python option, but I found that running the script alone only completed the basic setup of the solver and did not create the voxels or save files, so it cannot run successfully. Can I use the script to complete the entire simulation and post-processing process?
      lauener
      Z43
      wrote on last edited by lauener
      Hi!
      In all the tutorial python scripts this is shown. Within the python scripter you can click on the folder icon and choose "Open Example Script". There you will find lots of python scripts, that show how this is done.
      Here a small excerpt from the script "tutorial_emlf_parallel_plate.py":
      sim = CreateSimulation()
      s4l_v1.document.AllSimulations.Add(sim)
      sim.UpdateGrid()
      sim.CreateVoxels(path)
      sim.RunSimulation(wait=True)
      I suggest always creating a simulation, and an analysis function, that is then called in the RunTutorial function. It's best to then also create a main:
      def RunTutorial( path ):
      	import s4l_v1.document
      	s4l_v1.document.New()
      	CreateModel()
      	sim.UpdateGrid()
      	AnalyzeSimulation(sim)
      def main(data_path=None, project_dir=None):
      		data_path = path to a folder that contains data for this simulation (e.g. model files)
      		project_dir = path to a folder where this project and its results will be saved
      	import sys
      	import os
      	print("Python ", sys.version)
      	print("Running in ", os.getcwd(), "@", os.environ['COMPUTERNAME'])
      	if project_dir is None:
      		project_dir = os.path.expanduser(os.path.join('~', 'Documents', 's4l_python_tutorials') )
      	if not os.path.exists(project_dir):
      		os.makedirs(project_dir)
      	fname = os.path.splitext(os.path.basename(_CFILE))[0] + '.smash'
      	project_path = os.path.join(project_dir, fname)
      	RunTutorial( project_path )
      if __name__ == '__main__':
      	main()
