  4. How do I export multiple MATLAB files together?
9 Posts 4 Posters 5.0k Views 4 Watching
    gotou
    I am currently exporting EM potentials for various parts of the human body in MATLAB using the "Imp/Export" menu and the "MATLAB Exporter," but the large number of exports is taking a significant amount of time as I have to do them one by one. Is there a way to export them all at once?
      The easiest is to write a Python script. To learn how to write the script, I would first select one of the exporters, right-click to get the context menu, and select "To Python Script" (or similar). You can then modify the script to iterate over all fields, saving each to a separate file.
      L 1 Reply Last reply
      • brynB bryn
        lucky_lin
        @bryn
        Can GPU acceleration or multithreading parallel processing be used for post-processing with scripts?
          • L lucky_lin
            @bryn
            lucky_lin
            wrote on last edited by lucky_lin
            #5
            @bryn I want to export the TI electric field to a txt file, but each file is too large, and the number of digits for each electric field value is quite high, making the export process time-consuming. Is there a way to modify the number of digits in the exported data and choose to export only the electric field values without the coordinate points?
              The exporter currently has no option to set the precision. While this could be something we can add for an upcoming version, the text export will always be slow and create big files. It is simply not optimal.
              I guess you are exporting to .txt so you can process it in another tool? Which tool, or how do you want to use it downstream?
              Other options could be:
              • export to vtk (binary) format, or one of the XML vtk formats like .vtr. Many tools and libraries can read vtk files.
              • access the field as numpy array in python and export as whatever, e.g., .mat, .npz, as binary files, or csv (with your own formatting), etc.
              • brynB bryn
                lucky_lin
                @bryn I want to save the TI field as an npy file to serve as the input for a neural network. Would using a different file format be faster?
                  #8
                  You could probably export (XPostProcessor.VtkExporter or XPostProcessor.VtkXmlExporter, not sure it is in s4l_v1) it as a VTK file and modify your neural network DataLoader to support VTK files, e.g., via the meshio package or the much larger vtk package, or many others.
                  Or you could write a little Python script to grab the field data and save it to npy. To access the field, you would get the output of the extractor or pipeline entity in the analysis, say a FloatFieldData object. It has a Field(self, index: int) -> np.ndarray method to get the field as a numpy array, which you could save using e.g., np.save("filename.npy", fd.Field(0))
                    mypi
                    Hi there,
                    I hope you can help, and that my questions fits within this thread.
                    I have simulated an overall field and I would like to export it to matlab. At first I can live with the UI way i.e. by the import/export menu, but later I'd like to script it too. Now selecting e.g. the E-field and clicking the Imp/Export menu gives me no options but Import. Can anyone show the workflow? And/Or can anyone post a snippet of python code that does the export?
                    Does exporting require a certain license?
