  4. Access data directly
2 Posts 2 Posters 1.5k Views 2 Watching
  • P Offline
    P Offline
    parsley
    I'm trying to automatically access some data that you would usually display via the Tableviewers in S4L via my Python script. For example, after a lot of trial and error, I found the way to extract the psSAR via something like
    	average_sar_field_evaluator = analysis.em_evaluators.AverageSarFieldEvaluator(inputs=inputs)
    	average_sar_field_evaluator.TargetMass = 10.0, Unit("g")
    	average_sar_field_evaluator.UpdateAttributes()
    	document.AllAlgorithms.Add(average_sar_field_evaluator)
    	# perform the actual computation, throw an exception if an error occurs
    	assert average_sar_field_evaluator.Update(), 'ERROR, failed to compute SAR'
    	dictionary=average_sar_field_evaluator.Outputs[1].Data.DataJson
    psSAR=json.loads(dictionary)['simple_data_collection']['data_collection']['PeakValue']['data']
    Now, I'd also like to extract the reflection coefficient but I only got to
    em_sensor_extractor.Outputs["Reflection Coefficient(f)"].Data
    which does not return the numbers. How do I access it? Is there a general method or some place in the documentation that explains how to access the outputs of different algorithms?
      halder
      wrote on last edited by halder
      Hi, you can try something like the following to extract the reflection coefficient. You can always try to build extraction manually once and select "To python" by right-clicking on the end of the tree (i.e. the component you extract from your pipeline)
      import numpy
      import s4l_v1.units as units
      from s4l_v1 import Unit
      sim_name = "MRI Volume Coil Cleg = 29.5 pF" ###### define the sim name in this case this is a multiport FDTD simulation
      Adding a new EmMultiPortSimulationExtractor
      simulation = document.AllSimulations[sim_name]
      em_multi_port_simulation_extractor = simulation.Results()
      this is extracting a port
      inputs = [em_multi_port_simulation_extractor.Outputs["MRI Volume Coil Cleg = 29.5 pF - Endring source 1 (Birdcage 1)"]]
      em_port_simulation_extractor = analysis.extractors.EmPortSimulationExtractor(inputs=inputs)
      em_port_simulation_extractor.Name = "MRI Volume Coil Cleg = 29.5 pF - Endring source 1 (Birdcage 1)"
      em_port_simulation_extractor.UpdateAttributes()
      document.AllAlgorithms.Add(em_port_simulation_extractor)
      em_sensor_extractor = em_port_simulation_extractor["Endring source 1 (Birdcage 1)"]
      ref_coef_data = em_sensor_extractor.Outputs["Reflection Coefficient(f)"]
      ref_coef_data.Update()
      freqlist = ref_coef_data.Data.Axis
      ref_coef = refCoeff.Data.GetComponent(0)
      ref_coef_magnitude = np.sqrt(np.real(ref_coef)**2 + np.imag(ref_coef)**2)
      import matplotlib.pyplot as plt
      plt.plot(freqlist,ref_coef_magnitude)
