  4. AttributeError: 'NoneType' object has no attribute 'Results'
2 Posts 2 Posters 1.8k Views 2 Watching
    lucky_lin
    The simulation suddenly encountered this error, even though the same code was used previously without any issues.
    import numpy
    import s4l_v1.units as units
    from s4l_v1 import Unit
    try:
        ReleaseVersion.set_active(ReleaseVersion.version8_2)
        simulation = document.AllSimulations["0_17_35_29"]
        # Adding a new CurrentExtractor
        inputs = [em_sensor_extractor.Outputs["EM Potential(x,y,z,f0)"], em_sensor_extractor.Outputs["J(x,y,z,f0)"]]
        current_extractor = analysis.extractors.CurrentExtractor(inputs=inputs)
        current_extractor.IsoSurfacePerCentThreshold = 30.0
        current_extractor.UpdateAttributes()
        document.AllAlgorithms.Add(current_extractor)
    except Exception as exc:
        import traceback
        traceback.print_exc()
        # Reset active version to default
        ReleaseVersion.reset()
        raise(exc)
      You would get that error if there was no simulation named "0_17_35_29" in the currently opened document. Maybe you should check what simulations you have in your project and if you do have a simulation with that name?
      One way to list all simulation names via python is to run something like:
      for s in document.AllSimulations:
         print(s.Name)
