  4. Question about setting up sources in acoustic simulations
2 Posts 2 Posters 954 Views 2 Watching
  • K Offline
    K Offline
    Kihyun
    Hello, I bring in Sim4life in August and am currently studying it.
    I want to change the power source of the sound module.
    For example, I want to input a source that outputs 1% per second at Vpp: 10V, F = 500kHz.
    I don't know how to set this up. Can you help me?
      halder
      Hi @Kihyun,
      To create an acoustic simulation, click on “Sources”, then change the excitation signal from “Sinusoidal” to “User Defined.”
      This will provide an “Expression” field that you can edit as needed.
      I also recommend checking the Acoustic Tutorial in Section 3.7 of the Sim4Life Manual, which you can access from the top ribbon under “Help.”
