Importing file as a Label Field
Python API
10
Posts
5
Posters
3.5k
Views
5
Watching
Is this what you need? I can import stl file in this way.
file=model.Import('file address') -
Hi, not sure this api is already in the release version, but in the dev version there is
ImageModeling.ImportImage(filepath, as_labelfield: bool = False, tissuelist_path: str = "")This would allow you to import as labelfield and pre-assign the tissue names and colors.
If that doesn't work, you can access the options using following strategy:
- create an importer for the file,
- inspect the options.
This is a (general) solution to Import with the options:
imp = XCoreModeling.CreateImporterFromFile(file_path) imp.Options.ImportLabelField.Value = True imp.Import(file_path)To inspect the options, you can use the
DumpTreemethod:imp.Options.DumpTree() -
Is there a way how to import file such as *.nrrd or *.nii as a Label Field via python? Such an option is possible to select when importing the file via the GUI, however I can't find a way to do it via the python interface.
Regards,
Spuky
This post is deleted! -
