  4. Importing file as a Label Field
10 Posts 5 Posters 1.0k Views
    Spuky
    Is there a way how to import file such as *.nrrd or *.nii as a Label Field via python? Such an option is possible to select when importing the file via the GUI, however I can't find a way to do it via the python interface.
    Regards,
    Spuky
    P 1 Reply Last reply
      aridam
      any solution on this?
      Thanks,
      Arianna
      • F Offline
        F Offline
        fanruifu
        Is this what you need? I can import stl file in this way.
        file=model.Import('file address')
        A 1 Reply Last reply
        • F fanruifu
          aridam
          @fanruifu Thanks! Nop, these lines correspond in doing in thee GUI: import, select file, ok.
          I want to reproduce: import, select file, import file as a label field (pop up window that shows up when selecting the file), ok.
          I hope it is clear, thank you!
          • F Offline
            F Offline
            fanruifu
            How about this one.
            https://forum.zmt.swiss/topic/71/introducing-the-image-modeling-module-image-and-labelfield
              aridam
                Hi, not sure this api is already in the release version, but in the dev version there is
                ImageModeling.ImportImage(filepath, as_labelfield: bool = False, tissuelist_path: str = "")
                This would allow you to import as labelfield and pre-assign the tissue names and colors.
                If that doesn't work, you can access the options using following strategy:
                • create an importer for the file,
                • inspect the options.
                This is a (general) solution to Import with the options:
                imp = XCoreModeling.CreateImporterFromFile(file_path)
                imp.Options.ImportLabelField.Value = True
                imp.Import(file_path)
                To inspect the options, you can use the DumpTree method: imp.Options.DumpTree()
                  aridam
                  this is extremely useful! thanks a lot.
                  • S Spuky
                    Regards,
                    Spuky
                    P Offline
                    P Offline
                    PiersPiper
                    Banned
                    wrote on last edited by PiersPiper
                    • P Offline
                      P Offline
                      PiersPiper
                      Banned
                      #10
