How to use a script to automatically open an already run simulation
Simulations & Solvers
3
Posts
3
Posters
972
Views
3
Watching
@pyf
This is what I found in the tutorial scripts for thermal simulations.Check the RunTutorial function. It may help. Best.
def CreateModel():
...def CreateEmFdtdSimulation():
return em_simdef CreateThermalSimulation(em_sim):
return thermal_simdef AnalyzeEmAndThermalSimulation(em_sim,thermal_sim):
# Create extractor for the two simulation output filesem_results = em_sim.Results() thermal_results = thermal_sim.Results() # overall field sensors em_overall_field_sensor = em_results[ 'Overall Field' ] em_overall_field_sensor.Normalization.Normalize = True thermal_overall_field_sensor = thermal_results[ 'Overall Field' ] # Create a slice viewer for the SAR slice_field_viewer_sar = analysis.viewers.SliceFieldViewer() slice_field_viewer_sar.Visualization.Smooth = True slice_field_viewer_sar.Inputs[0].Connect( em_overall_field_sensor['SAR(x,y,z,f0)'] ) slice_field_viewer_sar.Update(0) slice_field_viewer_sar.GotoMaxSlice() document.AllAlgorithms.Add( slice_field_viewer_sar ) #THERMAL slice_field_viewer_t = analysis.viewers.SliceFieldViewer() slice_field_viewer_t.Visualization.Smooth = True slice_field_viewer_t.Inputs[0].Connect( thermal_overall_field_sensor['T(x,y,z,t)'] ) slice_field_viewer_t.Update(0) document.AllAlgorithms.Add( slice_field_viewer_t )def RunTutorial( path ):
document.New() CreateModel() em_sim = CreateEmFdtdSimulation() document.AllSimulations.Add(em_sim) em_sim.UpdateGrid() em_sim.CreateVoxels(path) thermal_sim = CreateThermalSimulation(em_sim) document.AllSimulations.Add(thermal_sim) thermal_sim.UpdateGrid() thermal_sim.CreateVoxels(path) em_sim.RunSimulation(wait=True) thermal_sim.RunSimulation(wait=True) AnalyzeEmAndThermalSimulation(em_sim,thermal_sim)if name == 'main':
RunTutorial( project_path )
