  4. How to use a script to automatically open an already run simulation
3 Posts 3 Posters 1.4k Views 3 Watching
  • P Offline
    P Offline
    pyf
    I need to add a temperature simulation to the EM simulation as well as the run
    S 1 Reply Last reply
      Have you created doing this manually and then right clicking on the final simulation and selecting 'To Python..'
      once you have your simulation object there should be something like sim.Run()
      • P pyf
        sayimgokyar
        @pyf
        This is what I found in the tutorial scripts for thermal simulations.
        Check the RunTutorial function. It may help. Best.
        def CreateModel():
        def CreateEmFdtdSimulation():
        return em_sim
        def CreateThermalSimulation(em_sim):
        return thermal_sim
        def AnalyzeEmAndThermalSimulation(em_sim,thermal_sim):
        # Create extractor for the two simulation output files
        em_results = em_sim.Results()
        thermal_results = thermal_sim.Results()
        # overall field sensors
        em_overall_field_sensor = em_results[ 'Overall Field' ]
        em_overall_field_sensor.Normalization.Normalize = True
        thermal_overall_field_sensor = thermal_results[ 'Overall Field' ]
        # Create a slice viewer for the SAR
        slice_field_viewer_sar = analysis.viewers.SliceFieldViewer()
        slice_field_viewer_sar.Visualization.Smooth = True
        slice_field_viewer_sar.Inputs[0].Connect( em_overall_field_sensor['SAR(x,y,z,f0)'] )
        slice_field_viewer_sar.Update(0)
        slice_field_viewer_sar.GotoMaxSlice()
        document.AllAlgorithms.Add( slice_field_viewer_sar )
        #THERMAL
        slice_field_viewer_t =  analysis.viewers.SliceFieldViewer()
        slice_field_viewer_t.Visualization.Smooth = True
        slice_field_viewer_t.Inputs[0].Connect( thermal_overall_field_sensor['T(x,y,z,t)'] )
        slice_field_viewer_t.Update(0)
        document.AllAlgorithms.Add( slice_field_viewer_t )
        def RunTutorial( path 😞
        document.New()
        CreateModel()
        em_sim = CreateEmFdtdSimulation()
        document.AllSimulations.Add(em_sim)
        em_sim.UpdateGrid()
        em_sim.CreateVoxels(path)
        thermal_sim = CreateThermalSimulation(em_sim)
        document.AllSimulations.Add(thermal_sim)
        thermal_sim.UpdateGrid()
        thermal_sim.CreateVoxels(path)
        em_sim.RunSimulation(wait=True)
        thermal_sim.RunSimulation(wait=True)
        if name == 'main':
        RunTutorial( project_path )
