  3. Volt and sensitivity of transducer sim4lite
2 Posts 2 Posters 389 Views 2 Watching
    Runner
    I am simulating ultrasound transducer.
    Is it possible to extract the volt at focused area?
    Also, I am wondering if it possible to extract the transducer sensitivity?, or at the focused area?
    Appreciate any input.
    Best Regards,
      Assuming a linear relation between voltage and pressure amplitude, you should be able to map the input voltage to the input pressure (I think its 1 MPa by default), and then use this as a scaling factor, but it's unclear to me what you mean with voltage at the focused area.
      What exactly do you mean by transducer sensitivity? You could run additional simulations where you shift the transducer or slightly change some parameters to get a sense of the sensitivity.
