  4. Extract EMLF Results via Jupyter
10 Posts 3 Posters 4.2k Views 3 Watching
  • C Offline
    cbenj33
    How do we extract EMLF results via Jupyter? I'd specifically like to know if there is a way to generate images of slice viewers via the API. I can see how to extract the data cache from an analysis, but I cannot seem to access results contained within the data cache, and I cannot find any documentation that supports how to do this.
    For context, I am running custom parameter sweeps via Jupyter. Every time we begin a new EMLF simulation with new settings, it deletes the results from the previous simulation. Automating the data extraction process is thereby very important for programmatic analysis downstream.
      To learn how to do this using the Python API, the most straightforward approach is to run the simulation, set up the analysis pipeline, and select, e.g., the slice field viewer and run the "To Python (selected)". This will generate the script and open it in the "Scripter" window.
      You can then edit and copy this code to a cell in your notebook.
      Many of the Jupyter notebook tutorials under Help -> Examples will run a simulation and extract results. Consider browsing through these to find examples most similar to your needs.
      • C Offline
        cbenj33
        Thanks @bryn, I had not seen the s4l.renderer package, it was somewhat hidden in the API browser.
        One question; is it possible to rotate a view with the API? I've been using renderer.SetViewDirection(Vec3(0, 0, -1)) to get a topdown view of my model, but I'd like to flip the view 90 degrees to the left before rendering an image.
        This is what I'm after:
        This is what I'm getting:
          Good question. The rotation of the camera around the view direction is not so easy to specify in the API.
          I can suggest the following workaround, in your target image the 'right' direction is negative Y
          cam = XRenderer.CameraSettings() # create a camera
          cam.Distance = 100  # instead, you could zoom to the bounding box, as shown in the Jupyter notebook examples
          cam.SetViewDirection(Vec3(0,0,-1), Vec3(0,-1,0))  # specify view direction and 'right' direction
          XRenderer.RestoreCamera(cam)  # tell the GUI to use these camera settings
          C 2 Replies Last reply
          • C Offline
            cbenj33
            wrote on last edited by cbenj33
            To follow up on my original question, is there any documentation or examples for extracting results from the exported data cache file?
              cbenj33
              Nice one @bryn , that seems to work well. Thank you.
                #7
                Cache files are not documented and are not intended as a format for data exchange. They are useful in Sim4Life to cache results and reload without re-running a full pipeline.
                Instead, I would use a different open format, like VTK (so-called legacy .vtk) or one of its XML variants (.vtr for rectilinear grids, .vtu for unstructured, .vtp for surfaces/lines). You can also obtain the data as numpy arrays and store it using a Python script, such as saving it as numpy, JSON, MATLAB, or some other file format, etc.
                If there is a different "results format" (grid + field distribution) you would love us to support, let us know, e.g., by posting in this chat.
                K 1 Reply Last reply
                  cbenj33
                  @bryn Actually I'm still having a bit of an issue with this. XRenderer.RestoreCamera does not update the GUI until end of execution, in both the scripter and via Jupyter. I'm trying to use the cam to determine orientation and then the renderer to zoom to my bounding box, but if the camera angle has been changed elsewhere, the cam won't be restored before zooming. Is there any way to force the GUI to update its view with RestoreCam before executing the zoom?
                  I know this is quite particular. Once again, the goal is to automatically generate screengrabs of viewers from multiple angles while running parameter sweeps. If there is no way to get exactly what I want then I'll try to simplify the goal, but it's so close to exactly what I'm trying to do and so I figure there must be a way. Thanks.
                  my code:
                  entity__simulation_boundary = model.AllEntities()["Simulation Boundary"]
                  renderer.ZoomToEntity(entity__simulation_boundary,1)
                  (again the above only works consistently if RestoreCam is executed first, and then ZoomToEntity. I've tried adding a time.sleep(0.1) in between the statements, but to no avail)
                    The RestoreCamera function has a second argument animate=True. Setting this to False should fix your issue.
                    If you are using s4l_v1.renderer.SaveScreenCapture to save an image of the scene in your script, you might need to give the GUI a chance to refresh during script execution. On Windows, you can do this with
                    win32gui.PumpWaitingMessages()
                    I typically do something like this
                    def refresh_gui()
                        if sys.platform == "win32":
                            import win32gui
                    for config in all_configurations:
                        # change the model, run a simulation, change camera settings, etc.
                        do_something(config)
                        refresh_gui()
                        s4l_v1.renderer.SaveScreenCapture(
                            width=1024,
                            height=1024,
                            multi_sample=True,
                            transparent_background=True,
                            output_folder="C\temp\screenshots"
                            output_prefix=f"subcase_{config}"
                      K Offline
                      K Offline
                      Kazu
                      @bryn Excuse me for butting in.
                      Nice to meet you. I’m currently a graduate student conducting research on temperature distribution in liver tumors with respiratory motion using Sim4Life.
                      Could you please share some code that uses Python scripts to output the analysis results of temperature distributions after running the simulation?
