  4. 2 Coils: Single or multi port?
2 Posts 2 Posters 925 Views 1 Watching
    Ari
    wrote on last edited by Ari
    I have two coils that are stimulated with an harmonic current signal, I want to evaluate the magnetic field between the two coils. I'm applying FDTD solver, I don't understand if I have to use the FDTD multi port or the single one.
    How do I decide it? I just noticed that multi port is faster in calculating the results. Thanks.
      sayimgokyar
      Hi Ari,
      It depends on your purpose.
      If you use single port simulation, then, you cannot later change the phase difference between the coils. However, if you use multiport simulation, Sim4Life runs 2 simulations for each coil and stores the results separately. This is useful if you would like to postprocess results for different source parameters. For example, you may change the current amplitudes for each coil, or add phase differences. You do not have to run the simulations again. New results will be directly calculated by using the previously stored multiport results.
      So, if you have enough memory and would like to try different settings for the sources, you had better to use multiport simulation for the above setup.
      If you want to save time and memory and fixed the source settings, then you may chose single port simulation.
      I hope this helps.
      Sayim
