  4. Different frequencies in electrodes
13 Posts 7 Posters 9.0k Views 7 Watching
    dstoupis
    I want to perform TACS (Trans-cranial Alternating Current Stimulation) with 2 electrode pairs, each at a slightly different frequency to create an envelope of the difference. I can not find something like that. The only thing that is possible is to use Electro Quasi-static LF Solver and have one frequency set.
    Do you know how can I achieve this?
      gagrafio
      If Superposition principle applies to your problem you can perform two separate simulations with the desired frequencies while using the same grid and extract the field values so you can post process on your own.
        Habib
        Hello dstoupis,
        I believe you aim to model the so-called temporal interference. The is a tool in Sim4Life for this called Max Modulation. You need two simulation with the same grid. Then you can multi-select the two fields in the Output View (each from one simulation) to have the Max Modulation button appear in the Ribbon.
        Best,
        Habib
        D P 2 Replies Last reply
        • P Offline
          P Offline
          prithn
          Sorry, to clarify, in order to set up the two different frequencies to model temporal interference, are we supposed to go into LF - Electro Quasi Static Simulation -> Setup -> Frequency? Or is this not the correct way to change the frequency?
          • H Habib
            Hello dstoupis,
            Best,
            Habib
            dstoupis
            wrote on last edited by dstoupis
            #5
            @Habib said in Different frequencies in electrodes:
            Hello dstoupis,
            Best,
            Habib
            Thank you @Habib!
            It was a simple selection of the two "Overall Fields" to have the "Max Modulation" tool show up! It helps a lot, since extracting the data and the processing it using Python to superimpose the fields and get the corresponding graphs, takes a lot of time.
            For future reference:
            1. Create two LF Electro Quasi-Static simulations one with the first desired frequency and another with the second desired frequency
            2. Use the same grid for the simulations (Grid point count must be the same)
            3. Run the simulations and extract the sensors
            4. Select the extracted sensors and magically the Max Modulation tool will appear
            H 1 Reply Last reply
            • D dstoupis
              Hello dstoupis,
              Best,
              Habib
              Thank you @Habib!
              hiTina
              @dstoupis
              also ,I have some questions when I perform the TDCS, when the max modulation appears, then what should I do to perform the next process? hope I can get your reply.
              D 1 Reply Last reply
              • H hiTina
                @dstoupis
                dstoupis
                @hitina
                Please explain what you mean. Have you performed the tDCS analysis and generated the temporal interference field?
                H 3 Replies Last reply
                • D dstoupis
                  @hitina
                  hiTina
                  @dstoupis Thanks for your reply.I have not generated the TI field.
                  I have some confused questions. I choose the LF-electro Quasi- static as the solver. I want to know how can I set up the boundary conditons .!微信图片_20211005204310.png what's more,as the picture shows,how to set up the the current and the voltage of the eletrode. be3c1df2-5328-4ecc-bc2e-8d08817a1d1a-image.png
                  I am learning the performance of transcranial temporal interference stimulation in this days.
                  hope your reply.
                  best wishes.
                  • D dstoupis
                    @hitina
                    hiTina
                    • D dstoupis
                      @hitina
                      hiTina
                      • P Offline
                        P Offline
                        PiersPiper
                        Banned
                        • H Habib
                          Hello dstoupis,
                          Best,
                          Habib
                          P Offline
                          P Offline
                          Pastis
                          @habib hello
                          i am performing TI simulation with sim4life and after using the max modulation to see the interference between the two field. I have electric field spreading all arround the mesh not only in the brain but in different part or the model (MIDA fULL aNISOTROPY MODEL).
                          And if i want to know which configuration of the electrode is better for TI simulation, should i compare the amount of electric field that reach the targeted region( for example in the hippocampus)?
                          • P Pastis
                            @habib hello
                            hiTina
                            @pastis Hello, Have you solved this question? can we compare the amount of electric field that reach the targeted region to evaluate the TI simulation ?
