  3. Installation & Licensing
  4. Problem with Sim4Life Light activation
6 Posts 4 Posters 4.0k Views 4 Watching
    Spuky
    wrote on last edited by Spuky
    Hello everybody,
    I have installed new version of Sim4Life Light 5.0.1.4765, however when I run (with administrator privileges, antivirus and firewall turned off) the Sim4Life for the first time, nothing is happening.
    In Task Manager I see the "FNPLicensingService64.exe" started. I made sure that Permissions for this *.exe file are set to Full Control. I tried to reinstall Sim4Life and also to install earlier 4.4. version without any success.
    Does anybody have any idea what should I do to make it work?
    Regards,
    Spuky
      Mélina
      Dear Spuky,
      After installing the Light version, when you launch it for the 1st time, you should normally have a pop-up asking you for your email address/activation code. Have you being able to do all this activation process?
      Best,
      Mélina
        Spuky
        Dear Méline,
        Thank you for your answer. There was no pop-up asking for email address/activation when I started it for the first time...
        Regards,
        Spuky
        • ofliO Offline
          Dear Spuky,
          Sim4Life Light V5.2.1 was recently released. Could you please try to install that version and let us know if you still experience issues. Thanks.
          Best,
          Erdem
          • PeterStijnmanP Offline
            PeterStijnman
            I had the same issue yesterday with installing Sim4Life Light V5.2.1. Uninstalling and reinstalling seemed to work for me to get the pop-up to activate a license. Hopefully the same works for you!
              Spuky
              #6
              Dear all,
              Thank you for your responses. The trick was in not "just" to disable the antivirus, but to completely uninstall it. Then the activation worked.
              Regards,
              Spuky
