  4. Voxel of a part of ViP models obtained with planar cutting
1 Posts 1 Posters 744 Views 1 Watching
    maxwell
    Z43
    When trying to voxel a part of ViP models (e.g., a hand from Duke) obtained with planar cutting, the following error may be encountered:
    Modeler : [Error] [facets_from_deep_copy]: Not a valid ENTITY type for this operation
    Error : Unable to voxel object which contains neither mesh nor wire data.
    This error is because the planar cut operation does not delete the empty meshes. A workaround is running the following script after selecting the model obtained with planar cutting:
    import XCoreModeling
    sel = XCoreModeling.GetActiveModel().SelectedEntities
    sel = XCoreModeling.CollectEntities(sel)
    empty = XCoreModeling.CreateGroup("Empty Meshes")
    for e in sel:
    if XCoreModeling.IsTriangleMesh(e):
    if e.Empty():
    print("%s is empty" % e.Name)
    empty.Add(e)
