  4. How do I calculate the full width at half maximum (FWHM) volume data in acoustic ultrasound simulation?
seftfwhmacoustic
3 Posts 2 Posters 5.3k Views 2 Watching
    Hank_H
    Hi
    I am using SEFT for ultrasound simulation.
    In the process of 'Analysis' results. I know how to view and get the result of maximum intensity from 2D slice view.
    Could anyone point out how to calculate the volume data of full width at half maximum?
      wrote on last edited by montanaro
      The easiest way to do it (that I know of) is rather awkward. You export the whole field results to a vtk file and then use vtk to calculate the isosurface / isocontour of the Full Width at Half Maximum, then import it back into the modeling of Sim4Life and go to Tools ->Geometry to get the data you need (Surface Area, Volume, Bounding box size, etc). I'll attach a Python script below to: Export Field Data to a vtk file and use python vtk to extract the Full Width at Half Maximum, and to import it back into S4L. Then, in the modelling tab you can select the object and go to Tools->Geometry to get the data you want.
      Notes:
      Make sure to update 'simulation_name' and that the correct field is selected ("Overall Field" and "p(x,y,z,f)" in this case)
      Select appropriate temporary file name and path in "vtk_exporter.FileName"
      Do appropriate postprocessing of data (in my case, pressure field is complex data, I took the absolute value of this data in this line:
      pabs = np.abs(pdata_wrapper.PointData[0] + 1j * pdata_wrapper.PointData[1])
      Select appropriate threshold ... Keep this if you want FWHM
      contour.SetValue(0, pabs_max / 2.0) # Half max
      Careful that data when imported back into s4l is scaled correctly (conversion from meters to mm)
      tr.Scale(1e3, 1e3, 1e3)
      import s4l_v1 as s4l
      import s4l_v1.units as units
      import vtk
      from vtk.numpy_interface import dataset_adapter as dsa
      from vtk.numpy_interface import algorithms as algs
      import numpy as np
      simulation_name = "Ac"
      # Select Simulation
      simulation = document.AllSimulations[simulation_name]
      acoustic_sensor_extractor = simulation_extractor["Overall Field"]
      # document.AllAlgorithms.Add(acoustic_sensor_extractor)
      inputs = [acoustic_sensor_extractor.Outputs["p(x,y,z,f)"]]
      vtk_exporter = analysis.exporters.VtkExporter(inputs=inputs)
      vtk_exporter.FileName = u"C:\\Users\\montanaro\\Desktop\\ExportedData1.vtk"
      vtk_exporter.Update()
      # Read in vtk file containing field
      reader = vtk.vtkDataSetReader()
      reader.SetFileName(vtk_exporter.FileName)
      # Convert cell centered data to node centered data
      # Needed for contour (isosurface) filter
      cell2point = vtk.vtkCellDataToPointData()
      cell2point.SetInputConnection(reader.GetOutputPort())
      cell2point.Update()
      # Turn into numpy array
      pdata = cell2point.GetOutput()
      pdata_wrapper = dsa.WrapDataObject(pdata)
      # Get absolute value of real and imaginary pressure
      # Create new field with this calculated data
      pdata_wrapper.PointData.append(pabs, 'pabs')
      pdata.GetPointData().SetScalars(pdata.GetPointData().GetArray('pabs'))
      # Create Contour Filter used to calculate isosurface
      contour = vtk.vtkContourFilter()
      contour.SetInputData(pdata)
      # Make sure we use correct scale between export and import
      tr = vtk.vtkTransform()
      transform = vtk.vtkTransformPolyDataFilter()
      transform.SetInputConnection(contour.GetOutputPort())
      transform.SetTransform(tr)
      # Write vtk file containing contour filter as an stl file
      writer = vtk.vtkSTLWriter()
      writer.SetInputConnection(transform.GetOutputPort())
      writer.SetFileName(vtk_exporter.FileName.replace(".vtk", ".stl"))
      writer.SetFileTypeToBinary()
      writer.Update()
      # Import back into S4L
      ents = model.Import(writer.GetFileName())
      H 1 Reply Last reply
      • M montanaro
        Notes:
        import vtk
        import numpy as np
        # Select Simulation
        cell2point.Update()
        writer.Update()
        Hank_H
        @montanaro
        Hi montanaro
        Thanks for all your help.
        I got your point in your above script and it works on python.
