  4. Calculating flux from simulation results - Improving Interpolation
interpolationpythoncodeexamplesanalysis
2 Posts 2 Posters 2.4k Views 2 Watching
  • J Offline
    J Offline
    Jexyll_S
    Hi everyone,
    I am trying to calculate the magnetic flux through a small, circular aperture using python scripts. My current process is to extract the values for the B-field from the simulation results, then add all the B-fields in a radius and multiply by the aperture area. The code for this is below.
    import numpy
    import s4l_v1.units as units
    from s4l_v1 import Unit
    	simulation = document.AllSimulations["Self Inductance TMS Device"]
    	B_field = em_sensor_extractor.Outputs["B(x,y,z,f0)"]
    	B_field.Update()
    	out = B_field.Data.Field(0)
    	# Extract and correct dimensionality
    	dims = np.array(B_field.Data.Grid.Dimensions)
    	if np.prod(dims) != len(out):
    		dims = dims - 1
    	# get x component of B-field. Reshape to correspond to volume
    	# Creates an array of [x,y,z] values
    	out_Bx = out[:,0].reshape(dims, order = 'F')
    	# Get cooordinates for cell nodes (not cell centres)
    	xaxis_nodes = field.Data.Grid.XAxis
    	yaxis_nodes = field.Data.Grid.YAxis
    	zaxis_nodes = field.Data.Grid.ZAxis
    	# Extrapolate coordinate points
    	xaxis = (xaxis_nodes[:-1] + xaxis_nodes[1:])/2
    	yaxis = (yaxis_nodes[:-1] + yaxis_nodes[1:])/2
    	zaxis = (zaxis_nodes[:-1] + zaxis_nodes[1:])/2
    	# Define circular apperture
    	centre = np.array([0, 0, -15])*1e-3
    	radius = 1*1e-3
    	# Find index closest to x-coordinate of centre
    	centre_idx_x = (np.abs(xaxis - centre[0])).argmin()
    	# Calculate flux through apperture
    	flux = 0.0
    	for y_idx, ycoord in enumerate(yaxis):
    		for z_idx, zcoord in enumerate(zaxis):
    			if ((ycoord - centre[1])**2 + (zcoord - centre[2])**2) <= radius**2:
    				# print("y and z coords are {} and {}".format(ycoord, zcoord))
    				# print("Value being added to flux is %f" % str(out_Bx[centre_idx_x, ycoord, zcoord]))
    				flux = flux + out_Bx[centre_idx_x, y_idx, z_idx]
    	flux = flux * np.pi * radius**2
    	print("Final flux is {}".format(flux))
    In addition, I also attempted using the flux evaluator tool. However, when I create circle entities, I am unable to extract any surfaces. Instead, I had to use an infinitely thin cylinder and apply suitable transforms to position it appropriately.
    import numpy as np
    from s4l_v1 import Vec3
    	ReleaseVersion.set_active(ReleaseVersion.version5_2)
    	cylinder2 = model.CreateSolidCylinder(Vec3(0,0,0),Vec3(0,0,0),0.5)
    	rotation = model.Rotation(Vec3(0,1,0), np.pi/2)
    	translation = model.Translation(Vec3(0,0,-15))
    	cylinder2.ApplyTransform(rotation)
    	cylinder2.ApplyTransform(translation)
    	cylinder2.Name = "Cylinder 2"
    	# Adding a new ModelToGridFilter
    	inputs = []
    	model_to_grid_filter = analysis.core.ModelToGridFilter(inputs=inputs)
    	model_to_grid_filter.Name = "Cylinder 2"
    	model_to_grid_filter.Entity = model.AllEntities()["Cylinder 2"]
    	model_to_grid_filter.MaximumEdgeLength = 7.07106769085e-05, units.Meters
    	model_to_grid_filter.UpdateAttributes()
    	document.AllAlgorithms.Add(model_to_grid_filter)
    	# Adding a new FieldInterpolationFilter
    	inputs = [em_sensor_extractor.Outputs["B(x,y,z,f0)"], model_to_grid_filter.Outputs["Surface"]]
    	field_interpolation_filter = analysis.core.FieldInterpolationFilter(inputs=inputs)
    	field_interpolation_filter.UpdateAttributes()
    	document.AllAlgorithms.Add(field_interpolation_filter)
    	# Adding a new SurfaceFieldFluxEvaluator
    	inputs = [field_interpolation_filter.Outputs["B(x,y,z,f0)"]]
    	surface_field_flux_evaluator = analysis.core.SurfaceFieldFluxEvaluator(inputs=inputs)
    	surface_field_flux_evaluator.UpdateAttributes()
    	surface_field_flux_evaluator.Update()
    	document.AllAlgorithms.Add(surface_field_flux_evaluator)
    	flux_data = surface_field_flux_evaluator.Outputs["Total Flux(B(x,y,z,f0))"].Data
    	mag_flux = flux_data.GetComponent(0)[0]
    	print("magnetic flux is {}".format(mag_flux))
    I prefer the second method, since it interpolates values, providing a more accurate measure of the flux. I wanted to post this code to provide some more references which new users of sim4life can draw from, and also to get feedback on my coding techniques.
    Cheers,
    Jexyll
      This looks quite good, thank you for providing your scripts.
      Note that, for the second method, you could create your cylinder directly at the desired position:
      cylinder2 = model.CreateSolidCylinder(Vec3(0,1,-15),Vec3(0,1,-15),0.5)
      There is also the XCoredModeling.CoverWires() function that allows you to make a surface (i.e. face) out of a circle entity.
      Last, but not least, note that the line model_to_grid_filter.MaximumEdgeLength is ultimately what determines the tradeoff between accuracy and computational cost of the interpolation (since it defines the resolution of the triangulated mesh on which the interpolation is done).
