  4. How Do I Precisely Align Sim4Life Models to each other
5 Posts 5 Posters 2.6k Views 5 Watching
  • C Offline
    C Offline
    charles.fawole
    When I imported the Sim4Life DUKE model and the FATS model into Sim4Life, the MALE model and the FATS model were not on top of each other. To fix this, I need to know the "center" of the MALE model and a “center” of the FATS model. If I know the "center" of the MALE model, then I can move the MALE model such that it has the same "center" as FATS model.
    Please what are the coordinates of “center” in Sim4Life models of DUKE, and also for BILLIE, THEO, and ELLA.
    Thank you.
      sayimgokyar
      Hello Charles,
      I was not able to find the center of the body models as well. But, here is my solution:
      Select the phantom (from Explorer window) --> Extract (Ribbon Menu) -> Bounding Box.
      This box gives you the corner coordinates of your body model. You can now find the center! Also, you can translate these models.
      Good luck.
        hyh
        In principle, the concept of alignment depends on the reference. e.g. brain scan and knee scan should have different alignment.
        Different model needs shifted or even rotated differently to align.
        You can tune in the modeller.
        S 1 Reply Last reply
        • H hyh
          Note that there is also a convenient "Geometry" tool in the "Tools" menu in the ribbon, which you can use to find the lowermost and uppermost corners of the bounding box of the selected item (for example the "Skin" tissue of the anatomical model, as in the attached screenshot, or one of the cranium bones if you would prefer to align models based on the center of the head).
          brynB 1 Reply Last reply
          • S Sylvain
            Note for MRIxViP we align the models by moving them such that the origin is
            the projection (closest point) of the saddle point between nose and frontal sinus, to the plane through the ear canal (perpendicular to view direction)
