  4. Delete Simulation and Results
13 Posts 4 Posters 5.8k Views 4 Watching
    LJ
    Does anyone know how to delete a simulation and its results using the Python API?
    SylvainS 1 Reply Last reply
      daolin_qu
      Why use Python api
      • L LJ
        @lj said in Delete Simulation and Results:
        Hi Lj,
        the commands below should help:
        sim = document.AllSimulations[0]    # access by index, starting with 0
        #sim = document.AllSimulations["my_simulation"]    # access by name
        sim.ClearResults()  # delete results
        sim.ResetVoxels()  # delete voxels
        document.AllSimulations.Remove(sim)   # remove simulation from project
          LJ
          Thank you @Sylvain!
          • L LJ
            Thank you @Sylvain!
            Thank you @Sylvain!
            you're welcome!
            I would also recommend using the auto-completion feature in the Console. For example, if you type
            sim=document.AllSimulations[0]
            to assign the sim variable and then sim followed by a . (dot) , you should see all the functions that you can use with this simulation object. Usually easier than trying to remember all of them :)
              LJ
              Yeah, I do use it. Its very helpful! I guess the mistake I was making was trying to find the delete/ remove within sim rather than document.allsimulations.
                yes, that one is not very obvious indeed. A hint might be given by looking at how simulations are "added" to the project (see for example the auto-generated code when you select a simulation and click "To-Python").
                  LJ
                  That makes sense- thank you!
                    michaelsch
                    after adding this lines i got this error :
                    Analysis : [Warn] Results Were Deleted
                    Analysis : [Warn] Results are not ready and simulation could not be located
                    Analysis : [Error] sim 2: Failed to compute output attributes
                    Analysis : [Error] Overall Field: Could not update input attributes
                    Analysis : [Error] EM E(x,y,z,f0) - Slice Viewer: Could not update input attributes
                    Analysis : [Error] EM Potential(x,y,z,f0) - Slice Viewer: Could not update input attributes
                    Analysis : [Error] EM E(x,y,z,f0) - Streamline Viewer: Could not update input attributes
                      michaelsch
                      also h5 output files disappear !
                        LJ
                        can you provide a bit more detail about what you're trying to do?
                          michaelsch
                          i load several meshes one of them is moving and also each time it transmit other frequency, so for each state i need different simulation (sweep not good for me)
                            LJ
                            wrote on last edited by LJ
                            #13
                            Hmm I am not sure I understand. Is it possible to share more of your code and explain exactly what is not working?
                            I use the lines of code you posted regularly and it works just fine.
