  4. Example of mask filter in postpro?
pythonmask filtersar
3 Posts 2 Posters 2.3k Views 2 Watching
  • pcrespoP Offline
    pcrespoP Offline
    pcrespo
    I have an e-field in a simulation. I would like to mask some regions to compute statistics. Is there an example/tutorial about how to do this in python? thx
    P.
      The typical workflow is to first build the postprocessing pipeline in the GUI, then use the "To Python" tool (available from the right-click contextual menu) to generate the corresponding Python script.
      For the mask filter + SAR statistics, it would give something like this:
      import numpy
      import s4l_v1.units as units
      from s4l_v1 import Unit
      simulation = document.AllSimulations["Dipole (Broadband) - Copy"]
      em_sensor_extractor.Normalization.Normalize = True
      em_sensor_extractor.Normalization.AvailableReferences = u"EM Input Power(f)"
      em_sensor_extractor.SurfaceCurrent.SurfaceResolution = 0.001, units.Meters
      entity1=model.AllEntities()['Sphere 1']
      # Adding a new FieldMaskingFilter
      field_masking_filter = analysis.core.FieldMaskingFilter(inputs=inputs)
      field_masking_filter.SetAllMaterials(False)
      field_masking_filter.SetEntities([entity1])
      field_masking_filter.UpdateAttributes()
      document.AllAlgorithms.Add(field_masking_filter)
      # Adding a new SarStatisticsEvaluator
      inputs = [field_masking_filter.Outputs["EM E(x,y,z,f0)"]]
      sar_statistics_evaluator = analysis.em_evaluators.SarStatisticsEvaluator(inputs=inputs)
      sar_statistics_evaluator.Snapshot = u"3e+08"
      sar_statistics_evaluator.StdDev = False
      sar_statistics_evaluator.TotalLossyVolume = False
      sar_statistics_evaluator.VoxelCount = False
      sar_statistics_evaluator.LossyVoxelCount = False
      sar_statistics_evaluator.UpdateAttributes()
      document.AllAlgorithms.Add(sar_statistics_evaluator)
      • pcrespoP Offline
        pcrespoP Offline
        pcrespo
        Thanks so much!
        P.
