  4. Sketch spline fails systematically
  • shernandS Offline
    shernandS Offline
    shernand
    I have a spline which is already in my CAD model d6ff49ad-c8bd-4c43-b87f-fc7780a8a8c8-image.png
    I want to basically "smooth" it, in the sense that I don't want wiggles (big second derivaties across its trajectory.
    So my plan is to:
    1. Extract points from the spline.
    2. Re-create a spline but only using a subset of the extracted points of the spline in question.
      I already extracted the points
      BUT now the Sketch-> Spline tool fails. It always creates a spline when I use two points. I therefore cannot create a spline with more than 2 points (which makes all of this pointless, well with two points actually :beaming_face_with_smiling_eyes: ).
      What can I do to get around this?
    Sergio Daniel Hernandez
    PhD student
    NeuroRestore | Defitech Center for Interventional Neurotherapies
    EPFL SV BMI UPCOURTINE
    (Website) http://neurorestore.swiss/
      I agree that it is unintuitive that the Spline tool stops when it snaps to a vertex. I will create a bug report.
      There are tools that may help you:
      • Wire Tools / Routings Tool Box / Approximate Wire
      • Wire Tools / Fit Spline
      The Approximate Wire tool allows you to specify the number of handles you want. It creates a parametric spline with handles (if Parametrize=True), so you can also edit it interactively by moving the handles.
      I guess you can also create a spline using a list of points using the Python API.
