  4. Problem with Boolean operation
2 Posts 2 Posters 1.3k Views 2 Watching
    lsc
    Re: Boolean operation with Anatomical models
    Hi all,
    I have a problem that looks similar. I would like to create a simulation of a transducer on a MIDA model of the head and would like to put a silicon patch between the transducer and the head. My idea was to do a boolean to substract the head on a small cylinder (reprensenting the patch). However, everytime I am doing a boolean this way, there is this error showing up:
    Modeler : [Error] CSG failed, exception: C:\projects\carve\lib\triangulator.cpp:1051 "didn't manage to link up hole!"
    Modeler : [Error] operation unsuccessful
    Modeler : [Error] [Subtract]: operation unsuccessful
    Which I don't understand....
    In more it creates weird shapes (probably due to my mesh).
    Do you have an idea of how I could create those patch to be sure that they are perfectly aligned with the head and without creating unwanted shapes.
    Thank you for your help !
      I think the error "didn't manage to link up hole" usually occurs when the two objects (involved in the boolean operation) have nearly parallel touching surfaces. You could try:
      • (always first make sure surfaces are manifold)
      • make the cylinder overlap more with (deeper in to) the skin
