  4. How to rotate an object with respect to a coordinate system (WCS) other than the object's center?
3 Posts 2 Posters 926 Views 2 Watching
  • F Offline
    F Offline
    Farhana
    I have to rotate an object w.r.t. a Coordinate System (WCS), which is different from the main Coordinate System. But I can find the only rotate option under the Translation menu, where if I enter z = 30 deg, then it rotates the object w.r.t. to it's own center.
    Can anyone please suggest how I can change the axis of rotation?
    Thanks.
    • F Offline
      F Offline
      Farhana
      I could figure out how to do it. The tutorial 'SAM Phantom with Generic Phone' helped.
      Thanks.
      S 1 Reply Last reply
      • F Farhana
        Thanks.
        sayimgokyar
        @farhana
        Good to hear this. I am using the following line of code to rotate an object around an arbitrary point (Xcenter, Ycenter, Zcenter) with rotation angles (Xtheta, Ytheta, Ztheta).
        This is more like a "Rotate" operation followed by a "Translate".
        Solid1.Transform = Transform( Vec3(1.0, 1.0, 1.0), Vec3(Xtheta, Ytheta, Ztheta), Vec3(Xcenter, Ycenter, Zcenter) )
