  4. Masking entities in python
6 Posts 4 Posters 3.6k Views 4 Watching
  • F Offline
    F Offline
    Frodi
    Hello Sim4Life community,
    I have problems changing the mask setting using the python API. I want to export data where the background is masked away. If I do it interactively in Sim4Life and choose 'to Python' the masking part of the code (setting entities to True/False) seems to be missing. I think I have to use the 'SetMaterial' function in the Analysis.Core.FieldMaskingFilter. I just can't figure out what input type it wants for the materials.
    Any help would be wonderful. This is my code:
    import numpy
    import s4l_v1.units as units
    from s4l_v1 import Unit
    try:
    ReleaseVersion.set_active(ReleaseVersion.version6_2)
    size = numpy.linspace(1,34,34)
    for k in size:
    	simulation = document.AllSimulations["Simulation  " + str(k)]
    	em_sensor_extractor.SurfaceCurrent.SurfaceResolution = 0.001, units.Meters
    	# Adding a new FieldMaskingFilter
    	field_masking_filter = analysis.core.FieldMaskingFilter(inputs=inputs)
    	field_masking_filter.UpdateAttributes()
    	document.AllAlgorithms.Add(field_masking_filter)
    	# Adding a new MatlabExporter
    	inputs = [field_masking_filter.Outputs["EM E(x,y,z,f0)"]]
    	matlab_exporter = analysis.exporters.MatlabExporter(inputs=inputs)
    	matlab_exporter.FileName = u"[some path]"+str(k)+".mat"
    	matlab_exporter.UpdateAttributes()
    	matlab_exporter.Update()
    	document.AllAlgorithms.Add(matlab_exporter)
    except Exception as exc:
    import traceback
    traceback.print_exc(exc)
    # Reset active version to default
    ReleaseVersion.reset()
    raise(exc)
    Best,
    Frodi
    S 1 Reply Last reply
    • F Frodi
      import numpy
      try:
      for k in size:
      import traceback
      raise(exc)
      Best,
      Frodi
      sayimgokyar
      @frodi
      I have a similar problem too.
      You may see my workaround in the post entitled as: ‘Exporting Simulation Results for Specific Tissues’.
      If you have a limited number of tissues, you may use my workaround. However, if the number of tissues are changing, then we need a different solution.
        Here is an example how you can change the mask programmatically, for materials that where already voxeled in the simulation:
            # - clear mask
            field_masking_filter.SetAllMaterials(False)
            # - add ventricles to mask
            materials = field_masking_filter.VoxeledMaterials()()
            for m in materials:
                if "Ventricle_lumen_left" in m.Name or "Ventricle_lumen_right" in m.Name:
                    field_masking_filter.SetMaterial(m.ID, True)
            field_masking_filter.Update()
        And here is an example of how you can use entities from the modeler:
            # somehow select certain entities
            entities = s4l.model.EntityList()
            selection = [e for e in entities if "Cerebellum" in e.Name]
            masking_filter.SetEntities(selection) # expects List[Entity]
            masking_filter.Update(0)
        • brynB bryn
              # - clear mask
              for m in materials:
          Spuky
          @bryn
          thank you for posting the code here, however could you please specify what should be the J_port in
          masking_filter.SetInputConnection(0, J_port)
          line of your code?
          Further in console, I got warning that this feature is DEPRECATED and it is recommended to use Inputs[key].Connect() however when I try to use
          masking_filter.Inputs[inputs].Connect()
          I receive error that there is no attribute Connect()
          Spuky
            @Spuky sorry, I guess the legacy code was confusing:
                masking_filter = s4l.analysis.core.FieldMaskingFilter()
            I edited the original answer to use the current API. The J_port was the output port for the J(x,y,z,f0) field.
            • brynB bryn
              Spuky
              wrote on last edited by Spuky
              #6
