  4. Avoid solid
Avoid solid
6 Posts 2 Posters 2.3k Views 2 Watching
    mkn
    I am modeling some neural pathways and portions of it go along the muscle layer in the human body model. Is it possible to avoid solid intersection?
    I came across something like this in the IMSafe toolbox:
    So I'm wondering if it is possible to do this using Python.
      The algorithm/evaluator is called:
      s4l_v1.analysis.em_evaluators.ImplantSafety
        Here is a script I found. Not sure it still runs, but I guess it should help you get started:
        import tempfile
        import os
        from s4l_v1.model import Vec3, Unit
        import s4l_v1.simulation as simulators
        import s4l_v1.simulation.emfdtd as emfdtd
        # Preamble ---------------
        import s4l_v1.document as doc
        sim = doc.AllSimulations[0]
        # assumptions
        sphere = model.AllEntities()["Sphere 1"]
        assert sphere
        assert isinstance(sim, emfdtd.Simulation)
        sim_xtor = sim.Results()  # pin this variable, otherwise wrapped members are deleted
        efield_port = sim_xtor["Overall Field"]["EM E(x,y,z,f0)"]
        hfield_port = sim_xtor["Overall Field"]["EM H(x,y,z,f0)"]
        # Demo ---------------------------------------------------
        from s4l_v1.analysis.em_evaluators import ImplantSafety
        from s4l_v1.analysis import RegisterAlgorithm
        # Creates ImSafe algorithm
        imsafe = ImplantSafety() # 0. create algorithm and connect to e-field port
        imsafe.SetInputConnection(0, hfield_port)
        # Disks options
        base_line = model.CreateSpline([Vec3(52.0, 0.0, 0.0), Vec3(0, 32, 0), Vec3(-9, 70, 0)])
        imsafe.SetBaseLine(base_line)  # 1. define baseline
        total_len = imsafe.EvalBaseLineLength()
        imsafe.ModelUnits = Unit.MilliMeter
        imsafe.SetDisks(
            position=[0, 0.1, 1], radii=[10.0] * 3
        )  # 2. define disks along baseline
        centers, normals, radii = imsafe.GetDisks()
        print("centers", centers, imsafe.ModelUnits)
        print("normals", normals, imsafe.ModelUnits)
        print("radii", radii, imsafe.ModelUnits)
        # Line generation options #3. setup line options
        imsafe.NumberOfLinesProp.Value = 5
        imsafe.LengthDeviationProp.Value = 10  # %
        imsafe.NormalToEndDisksProp.Value = True
        imsafe.MinSplineResolutionProp.Value = 0.01 * total_len  # or
        # imsafe.MinSplineResolutionProp.SetValueAs(0.05, Unit.Meter)
        imsafe.EnableConstraintsProp.Value = False  # 4. setup obstacles
        imsafe.SetAsObstacles([sphere])
        RegisterAlgorithm(imsafe)
        assert imsafe.UpdateAttributes(), "Guarantees output ports are updated"
        imsafe.ClearOutputLines()
        assert imsafe.Update(0)
        filepath = os.path.join(tempfile.mkdtemp(), "line.txt")
        print("Exporting to", filepath)
        imsafe.ExportLines(filepath, snapshot_index=0)
        imsafe.ImportLines(filepath)
        # Creates viewer
        import s4l_v1.analysis.viewers as viewers
        dv = viewers.SurfaceViewer()
        dv.SetInputConnection(0, imsafe.GetOutputPort(2))
        RegisterAlgorithm(dv)
          • it simply takes the first simulation. Note, the evaluator needs an existing simulation because it tests if the splines pass through voxels of the "Entities to Avoid" list
          • the entities to avoid are set via SetAsObstacles(entity_list). the script assumes this entity is called "Sphere `"
          • the script creates a spline as baseline, but you could also create the baseline in the GUI, and get it via base_line = model.AllEntities()["My Baseline"]
            mkn
            Thanks for the scrip @bryn. I am actually curious if it is possible to set an obstacle to avoid in the modelling window when drawing an object, outside of IMSafe.
              Only by snapping to objects. One strategy can be to use planar cuts to snap inside solids/surfaces
