  4. How to interpret JsonDataObject data (e.g. from Statistics evaluator)
python
1 Posts 1 Posters 981 Views 1 Watching
    Recently I was trying to extract the average field value using the Sim4Life Python API. Since I found interpreting the JsonDataObject a bit difficult, I will share the code here. Hope it helps.
    # -*- coding: utf-8 -*-
    # This script was auto-generated by Sim4Life version 7.1.0.8835
    import numpy
    import s4l_v1.units as units
    from s4l_v1 import Unit
    try:
        ReleaseVersion.set_active(ReleaseVersion.version7_1)
        simulation = document.AllSimulations["EM"]
        em_sensor_extractor.SurfaceCurrent.SurfaceResolution = 0.001, units.Meters
        # Adding a new StatisticsEvaluator
        inputs = [em_sensor_extractor.Outputs["SAR(x,y,z,f0)"]]
        statistics_evaluator = analysis.core.StatisticsEvaluator(inputs=inputs)
        statistics_evaluator.Mode = u"Value"
        statistics_evaluator.UpdateAttributes()
        document.AllAlgorithms.Add(statistics_evaluator)
        statistics_evaluator.Update()
        # Get JsonDataObject output and print the values
        stats = statistics_evaluator.Outputs[0].Data.DataSimpleDataCollection
        for k in stats.Keys():
            v = stats.FieldValue(k, 0)
            unit = stats.FieldUnit(k)
            name = stats.FieldDescription(k)
            print(f"{name} = {v} {unit}")
    except Exception as exc:
        import traceback
        traceback.print_exc()
        # Reset active version to default
        ReleaseVersion.reset()
        raise(exc)
    The output is:
