How to Change Material Properties with Python?
Scheduled Pinned Locked Moved Unsolved Python API
emfdtdpythonmaterialpython api
5 Posts 4 Posters 299 Views
    dbsim4
    wrote on last edited by dbsim4
    I'm trying to change EMFDTD material properties in a simulation that's already set up, using the VIP Body Models.
    If I change the conductivity value, it immediately resets itself to the original value - how do I get it to keep my new value?
    I'm getting "s" from this answer, to get the list of materials:
    https://forum.zmt.swiss/topic/16/how-to-update-material-settings-using-the-material-database-from-python/2
    Thank you!
  • D dbsim4 marked this topic as a question on
  • K Offline
    K Offline
    Konohana
    Hey there,
    I am not sure if this will fix your issue, but I can provide you with a piece of code that I used to apply material settings to the tissues in my simulations:
    # dictionary containing all tissue names and entities in the simulation:
    all_tissues_present = {}
    if 'Bone_cortical' in all_entities:
    	print('Bone assigned')
    	entity_bone1 = all_entities["Bone_cortical"]
    	all_tissues_present["Bone_cortical"] = entity_bone1
    # Dictionary containing material properties such as conductivity
    tissue_conductivities = {
    	'Scalp': [0.439, 1],
    	'Cerebrum_white_matter': [0.348, 10],
    	'Cerebrum_grey_matter': [0.419, 9],
    	'Cerebrospinal_fluid': [1.88, 8],
    	'Bone_cortical': [0.00645, 3],
    # Code to assign material settings to the correct tissues. Using the dictionaries above this can then be done in a for-loop:
    for tissue_name, tissue_entity in all_tissues_present.items():
         material_settings = emlf.MaterialSettings()
         components = [tissue_entity]
         material_settings.Name = tissue_name
         material_settings.ElectricProps.Conductivity =
         tissue_conductivities[tissue_name][0], Unit("S/m")
         simulation.Add(material_settings, components)
    I hope this helps and wish you a very nice day.
    Best
    dbsim4
    Thank you very much, this is really helpful!
    How do you access the initial "all_entities" list?
    I've tried
    for e in model.AllEntities:
    	print(e)
    but I this error:
    TypeError: 'type' object is not iterable
  • B Online
    B Online
    try for e in model.AllEntities():
    michaelsch
    Mesh_material = sim.AddMaterialSettings(themesh(fromstl))
    Mesh_material.Name = yourname
    Mesh_material.ElectricProps.Conductivity = v # S/m
