  4. Error : Can't create attribute 'material_version'.
1 Posts 1 Posters 755 Views 1 Watching
    michaelsch
    hello
    i based on example of 2 plates
    \Sim4Life\7.0\Documentation\Tutorials\Tutorial Scripts\tutorial_emlf_parallel_plate.py"
    i load some mesh use stl then assign material
    now i run simulation it ended successfully but no fields created.
    now i add source as positive and negative and run simulation again i got
    Error : HDF5 error(s):
    Attribute - Unable to initialize object: unable to create attribute
    Attribute - Unable to create file: unable to create attribute
    Attribute - Object already exists: attribute already exists
