  4. move pallet missing in 7.0
11 Posts 7 Posters 5.5k Views 7 Watching
  • T Offline
    T Offline
    tiwwexx
    Hello, I've a bugs in s4l 7.0.1.8169
    The first is that I don't have the pallet that comes up when I try to use the move tool in the model section. Along these same lines, when I click on an object I no longer have a pop-up menu (see attached pics, the one on the top is in 7.0 the bottom two are 6.2)
    • ofliO Offline
      wrote on last edited by ofli
      Please open the Console window via VIEW | Console and check the OpenGL version and also see if there are any other warning/error messages. The floating sub-context in the 3D window is used to show up only for OpenGL version > 3.2 (or a similar). Are you using Sim4Life locally or via Remote Desktop?
      • T Offline
        T Offline
        tiwwexx
        I have an OpenGL error when I open S4L and I'm using a Remote Desktop. The desktop currently only has compute GPUs in TCC mode so it's using onboard graphics.
        M 1 Reply Last reply
        • D dbsim4 referenced this topic on
          dbsim4
          I noticed a similar problem with the Poser Tool buttons missing; I posted it as a separate question here:
          https://forum.zmt.swiss/topic/480/poser-tool-apply-button-missing-in-version-7
          Any help is greatly appreciated!
          • T tiwwexx
            Mélina
            Hi @tiwwexx, to solve this issue, you can try to update your OpenGL to a version > 3.2. Also, you can try to use another remote desktop tool than the one you are currently using - it is possible that some mismatches in the OpenGL version happen.
              rob
              Hi, I have the same problem (move pallet missing). On my workstation OpenGL 4.5 is installed. But the console output states OpenGL 3.0.14800 is initialized... Any help is greatly appreciated.
              Console output:
              Initialized OpenGL 3.0.14800 Compatibility Profile Context FireGL 22.Q2 30.0.21020.2[AMD Radeon (TM) Pro WX 7100 Graphics], backwards compatible, 8 multi-samples
              [Info] Started worker process on port=9090
              • V Offline
                V Offline
                VigneshYork
                Hi, has there been any update on how to get the move pallet? I have opengl version 4.2 but still no luck
                S 1 Reply Last reply
                • V VigneshYork
                  s279408
                  @VigneshYork I solve it by modifying graphic properties on my laptop on the windows menu: Screen>Graphic and then working on S4L app from there (advanced properties if i remember correctly)
                  • V Offline
                    V Offline
                    VigneshYork
                    Hi s279408, thank you for your reply. May I know what properties did you change? Are you working remotely or on your local machine?
                    • V VigneshYork
                      s279408
                      wrote on last edited by s279408
                      #10
                      @VigneshYork
                      Here in my local machine. I'll post what the support send me by mail when I asked for help
                      "Check which version of OpenGL you get when starting Sim4Life. You can read it in the console (to open the console go to VIEW and select Console). If it is less than 3.1, they recommend:
                      • Install latest GPU driver version, make sure GPU supports OpenGL > 3.0
                      • Laptops often have low power settings for GPUs, make sure it is set to max performance.
                      • Try to avoid remote desktop or virtual machine. These can typically influence the graphics context."
                      Maybe it doesn't help but at least I tried
                      • V Offline
                        V Offline
                        VigneshYork
                        Thanks a lot
                        • ofliO ofli referenced this topic on
