  4. Pose User-Defined Surfaces/Entities
39 Posts 3 Posters 71.0k Views 3 Watching
    The solver will treat the bone as muscle tissue,ie the properties matter. There will be no bone muscle interface.
    V 1 Reply Last reply
    • V Offline
      V Offline
      VigneshYork
      Thank you. I have one last question: Are there any tutorials using the FDFD solver?
      • V Offline
        V Offline
        VigneshYork
        Hello Bryn,
        I would like to confirm the difference between the option "distribute along line" in the sources settings.
        Does not choosing the option introduce a time delay/phase delay for the antenna (patch antenna) for example? Is there a method of calculating the time delay for an antenna?
        Vignesh
          Hi @VigneshYork
          Please open a new topic. The questions about FDFD (yes there are tutorials) / source settings are unrelated to the poser.
          This will help make the forum more useful for others (or you, next time). It also is more likely to get answered by somebody who knows the topic.
          • V Offline
            V Offline
            VigneshYork
            Hi Bryn,
            I apologise.
            • V Offline
              V Offline
              VigneshYork
              I have two questions regarding the pose tool:
              1. In the example stated at the start of this thread regarding drawing a patch on the surface of the skin and posing the patch with the model: would the patch also deform similar to the skin? Is the FEM applied to the patch also?
              2. I am getting the following issue (figure attached). The bone and muscle are split. I am not sure how to fix this
                1. the FEM model is used to compute a deformation in the entire body. The deformation is applied to all surface entities (and patches defined on those surfaces). A patch on a triangle mesh is actually just a subset of that surface (a list of triangles).
                2. I have never observed this issue. Did you use the move tool before/after/while using the poser? Can you explain the steps to reproduce this issue?
                • V Offline
                  V Offline
                  VigneshYork
                  Hi Bryn,
                  Thanks for your clarifications.
                  1. If I extrdue the patch to make a cloth or band around the leg. Would that deform too?
                  2. The way to reproduce the issue is to move the model to a different location and then pose it.
                    ok,
                    1. if the extrusion layer is thin enough it may deform reasonably. Deformation of surfaces outside the body is based on nearest neighbor extrapolation. You could also extrude the patch after posing.
                    2. Thanks, I will create a bug report so we can address it. I guess a workaround is to move after posing. Sorry for the inconvenience.
                    • ofliO Offline
                      @VigneshYork Which Sim4Life version are you using?
                      • V Offline
                        V Offline
                        VigneshYork
                        Hi, I am using version 7.0.1.8169
                        • ofliO Offline
                          Please download and install the latest version of Sim4Life (V7.2.4) with which you should not experience this issue.
                          • brynB bryn
                            V Offline
                            V Offline
                            VigneshYork
                            @bryn I have a follow up question to this. If I draw a cylinder over the bone and provide it properties of muscle, do I need to subtract the bone from the cylinder?
                            For example: When I observe the voxels in the ViP model for muscle only (without the presence of bone or anything), there is a hole where the bone is suppoed to be (which makes sense) (Figure attached).
                            Do I need to do the same with a custom cylinder i.e subtract the bone from the cylinder? The voxels with the cylinder with bone shows the presence of the bone (Figure attached) but not for all cases.
                              you can, but it is easier to simply use the priorities. if you set the cylinder to a higher priority than bone it will be voxeled over the bone. a voxel can only represent one material, so what ever has higher priority wins.
                              • V Offline
                                V Offline
                                VigneshYork
                                Thank you. What happens when all elements are given the same priority and you do not subtract the bone from the muscle? What would a voxel at the location of the bone present?
                                @ofli : Thank you. Installing the new version removed the error.
                                brynB 1 Reply Last reply
                                • V VigneshYork
                                  @VigneshYork it will seem like a random ordering. If I remember correctly, the ordering will depend on the unique identifier of the entities (entity.Id). If you need to ensure a specific ordering you have to use the priorities (OR do the boolean subtraction). The priority approach is very robust though.
                                  • V Offline
                                    V Offline
                                    VigneshYork
                                    Thank you
                                    • V Offline
                                      V Offline
                                      VigneshYork
                                      @ofli : sorry but the error happened again with sim4life 7.2. Once I moved the model and tried to pose it, the bones and rest of the model separated
                                      • V Offline
                                        V Offline
                                        VigneshYork
                                        Hi Bryn,
                                        I would like to ask a question regarding posing. My aim is to detect the variation in bone position from the skin in different poses (hypothesis being: as the soft tissues deform, the bone wont always be at the same position wrt the skin). I currently have 8 antennas placed around the skin which are supposed to mimic wearable antennas and I would like to move these antennas along with the pose.
                                        But if I link these antennas to the bone using "link-parent tool", the bone is always at the same location wrt to the bone irrespective of the pose. But I cannot link the antennas wrt to the skin as the antennas dont move with the pose.
                                        1. How can I do this? I would like the antennas which are placed around the skin to similar to the skin rather than the bone?
                                        2. Based on the first video in this chain, triangular meshes can be posed similar to the body. If I convert the antennas to meshes and then pose it, will I be getting the same issue i.e the bone is always at the same location wrt to the antennas?
