  4. Installing Additional Python Packages in Sim4Life Environment
Scheduled Pinned Locked Moved Solved Python API
pythonpip
9 Posts 3 Posters 5.4k Views 3 Watching
    andrea_h
    wrote on last edited by andrea_h
    Hi all,
    I have been working with the Sim4Life Visual Studio Code Extension. While some modules like numpy work perfectly, others give a "ModuleNotFoundError."
    I believe this is because I am running my script in the Sim4Life environment, and certain packages are not included by default.
    My question is: Is there a way to install additional packages within the Sim4Life environment so I can use them in my scripts?
    Any suggestions or guidance would be greatly appreciated! 🙂
    • A andrea_h marked this topic as a question on
      yes, you can install additional packages in the Python environment that Sim4Life is running. Simply type this in a console (using e.g. "cmd.exe"):
      "C:\Program Files\Sim4Life_xyz\Python\python.exe" -m pip install package_name
      adjusting for Sim4Life's version number and your package_name.
      You most likely won't even need to restart Sim4Life.
      G 1 Reply Last reply
        andrea_h
        Thanks for your response! It worked perfectly 🙂 (without even restarting Sim4Life)
        • S Sylvain has marked this topic as solved on
        • S Sylvain
          gc00
          @Sylvain I would like to add new packages too (e.g., dipy), but I don't have such directory in my computer, is it a problem?
          Despite the fact I have not a python.exe, I can run Python script in Sim4Life.
          Thanks in advance!
          S 1 Reply Last reply
          • G gc00
            Thanks in advance!
            #5
            @gc00 try typing this in Sim4Life's console (View -> Console), it will give you a clue as to the location of the Python directory:
            import os
            print(os.__file__)
            G 2 Replies Last reply
            • S Sylvain
              import os
              print(os.__file__)
              gc00
              • S Sylvain
                import os
                print(os.__file__)
                gc00
                @Sylvain it printed: C:\Program Files\Sim4Life_7.2.3.12730\Python\lib\os.py
                  then it means that you can find python.exe in this directory:
                  So you should be able to run:
                  "C:\Program Files\Sim4Life_7.2.3.12730\Python\python.exe" -m pip install package_name
                  from Windows' console (NOT the Console of Sim4Life)
                  • S Sylvain
                    gc00
                    @Sylvain Yes thanks finally I succeed!
