  4. T-Neuro
  5. Source pulse parameter on EM-LF simulation on Yoon-son model
Scheduled Pinned Locked Moved Unsolved T-Neuro
5 Posts 3 Posters 2.6k Views 3 Watching
  • V Offline
    V Offline
    viniltc
    wrote on last edited by viniltc
    Hi all,
    I'm running an EM-LF (Electro Ohmic Quasi-static) simulation using the Yoon-son anatomical model and would like to apply a bi-phasic pulse with a defined amplitude and pulse width across an electrode pair.
    What is the recommended approach for implementing this type of time-dependent source condition in the simulation setup?
    Can this be directly defined in the solver settings, or does it need to be modeled through post-processing?
    Any guidance or examples would be greatly appreciated.
    Many thanks in advance.
    • C Offline
      C Offline
      carbonell
      There are different ways to apply the modulation pulse in your simulation.
      • If you are aiming to simulate neuro-stimulation, you should link your EM-LF simulation to a NEURON simulation. In this case, you can define the modulation pulse using the NEURON Source settings by selecting "Bipolar" as the Pulse Type. For a detailed example, I recommend checking out the Yoon-Sun Arm Stimulation tutorial.
      • If you are not doing neuromodulation, but instead you are interested in dosimetry, you can also apply the modulation pulse as a post-processing step using the Python API. Below is an implementation example (to adapt to your pulse signal and project).
      I hope this helps.
      from collections import defaultdict
      from pathlib import Path
      import matplotlib.pyplot as plt
      import numpy as np
      import s4l_v1.materials.database as database
      import s4l_v1.units as units
      import XCoreModeling as xcm
      import XPostProcessor as xp
      from s4l_v1.data import TutorialDataDirectory
      from s4l_v1.model import Vec3
      from s4l_v1.renderer import SetViewDirection, ShowScreenCapture, ZoomToEntity
      from s4l_v1.simulation import emlf, neuron
      import numpy as np
      def create_data_producer(
          x_array, data_array, x_name, x_unit, y_name, y_unit, name, iscomplex=True
          if iscomplex:
              data = xp.ComplexFloatXYData()
          else:
              data = xp.FloatXYData()
          quantity = xp.Quantity()
          quantity.Name = y_name
          quantity.Unit = xp.Unit(y_unit)
          data.Quantity = quantity
          assert data.Allocate(len(data_array), [1])
          data.Axis = x_array.astype(np.float64)
          quantity.Name = x_name
          quantity.Unit = xp.Unit(x_unit)
          data.AxisQuantity = quantity
          if iscomplex:
              data.SetComponent(0, data_array.astype(np.complex64))
          else:
              data.SetComponent(0, data_array.astype(np.float32))
          # producer
          producer = analysis.core.TrivialProducer()
          producer.SetDataObject(data)
          producer.Description = str(name)
          document.AllAlgorithms.Add(producer)
          return producer
      # define short rectangular pulse (to be changed with custom pulse)
      t_1 = 0.5 * 1e-3  # s
      pulse_amplitude = 1
      pulse_duration = 0.3 * 1e-3  # s
      t_max = 3 * 1e-3
      Nt = 5001
      dt = t_max / Nt
      t_array = np.linspace(0, t_max, Nt).astype(np.float32)
      pulse_array = np.zeros_like(t_array)
      pulse_array = np.where(
          (t_array > t_1) & (t_array <= t_1 + pulse_duration),
          pulse_amplitude,
          pulse_array,
      modulating_pulse_producer = create_data_producer(
          t_array,
          pulse_array,
          "Time",
          "s",
          "Modulation(t)",
          "Modulating Pulse",
          iscomplex=False,
      simulation = document.AllSimulations["Your Simulation Name"]
      # Attach modulation to quasi-static EM field
      inputs = [em_sensor_extractor.Outputs[0], modulating_pulse_producer.Outputs[0]]
      modulated_field = analysis.core.ModulatedFieldEvaluator(inputs=inputs)
      modulated_field.UpdateAttributes()
      modulated_field.Name = "Modulated Efield"
      document.AllAlgorithms.Add(modulated_field)
      • V Offline
        V Offline
        viniltc
        • V Offline
          V Offline
          viniltc
          Hi @carbonell ,
          Thanks for the information.
          I’m currently working on Sim4Life IO, but this is my first time using the Python API within this platform.
          Here’s what I’ve tried so far:
          • I launched JupyterLab from the Sim4Life IO interface.
          • I copied and pasted the example code into a notebook and ran it cell by cell.
          However, I encountered the following error:
          AttributeError                            Traceback (most recent call last)
          Cell In[4], line 37
               34 # Creating the analysis pipeline
               35 # Adding a new SimulationExtractor
               36 simulation = document.AllSimulations["Simple ES"]
          ---> 37 simulation_extractor = simulation.Results()
               39 # Adding a new EmSensorExtractor
               40 em_sensor_extractor = simulation_extractor["Overall Field"]
          AttributeError: 'NoneType' object has no attribute 'Results'
          It seems like simulation is returning None, but I’ve already created a simulation named “Simple ES” in the GUI.
          Is there something I’m missing in how simulations are referenced or accessed in Sim4Life IO via Python?
          Any help or pointers to relevant documentation would be greatly appreciated.
          brynB 1 Reply Last reply
          • V viniltc
            Hi @carbonell ,
            Cell In[4], line 37
            #5
            @viniltc, the error looks like you do not have a simulation called "Simple ES" (the returned simulation is None). Please double-check the name, including white-spaces. You can also access by index (document.AllSimulations[0]).
